Author Topic: Need help with creating a batch file  (Read 1920 times)
vibez
  • Last login:February 09, 2011, 08:33:20 am
« on: July 11, 2005, 02:53:44 pm »
Basically I have a program that needs to be run from a batch file or commandline.
It converts several files into 1 large one.
The format of the command line is (minus the brackets)
[output.qch] [input1.cod] [input2.cod] [input.3cod] etc....
I have a folder of about 1000 .cod files. I dont fancy typing that all out on a commandline.
Is there a way to create some batch file that will get the name of all the .cod files & feed it into a commandline like the one above? All the input.cod files need to be on one line
I tried
output.qch *.cod
but it moans about the *
« Last Edit: July 11, 2005, 03:06:11 pm by vibez »
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
Re: Need help with creating a batch file
« Reply #1 on: July 11, 2005, 04:24:12 pm »
Is this Windows or elsewhere?
If windows, do the following:
In the directory that has the .cod files from a command line do:
dir /B *.cod >c:\filename.txt
Where filename.txt is the path/output file you want.
This will give you just a listing of the filenames.
Next, create a batch file with the following:
FOR /f "tokens=1 delims=;" %%l in (c:\filename.txt) DO output.qch %%l
although, I dunno if that'll work since I have not idea what a qch file is but this works very well for other purposes.
« Last Edit: July 11, 2005, 04:27:02 pm by NinjaEpisode »
vibez
« Reply #2 on: July 11, 2005, 04:38:35 pm »
Yes it is unders windows.
I get this error
"%%l was unexpected at this time."
Can I email you the files for you to test with?
vibez
« Reply #3 on: July 11, 2005, 06:06:20 pm »
Ok I have it almost working now :) :)
Only trouble is that it is not putting all the input.cod names on one line, but is feeding them to the program 1 at a time like the example below
FOR /F "tokens=1 delims=;" %l in (c:\filename.txt) do cod2qch output.qch %l
this is the result
C:\cod2qch output.qch input1.COD
C:\cod2qch output.qch input2.COD
C:\cod2qch output.qch input3.COD
C:\cod2qch output.qch input4.COD
« Last Edit: July 11, 2005, 06:08:20 pm by vibez »
NinjaEpisode
« Reply #4 on: July 11, 2005, 07:37:59 pm »
Oh I see.
Do you have MS Word?
Cut and past the list from the text file into MS Word.
Select Edit, Replace (Might be search & replace)
In the find section, input ^p
In the replace section, push your spacebar once.
Hit replace all.
This should take all the files and remove the return carriage and then put a space between each of them.
You can then cut and past into a new batch file with your call.
vibez
« Reply #5 on: July 12, 2005, 03:18:54 am »
Thanks ever so much. That worked perfect :)
Is there no way to modify the batch so we dont need the use a word editor?
NinjaEpisode
« Reply #6 on: July 12, 2005, 07:14:35 am »
There are all kinds of text editors that can detect and modify the special characters such as a carriage return.  As long as the editor can detect the formatting, you should be able to use what you like.  Word just came to mind because it's what I use regularly.
Scripting the whole thing is possible, but considering the amount of time it takes just to do a quick find and replace, I don't know that it's worth it.
vibez
« Reply #7 on: July 12, 2005, 09:03:10 am »
That is very true. I guess we dont even need the batch file once we have the filename directed to a text file. It just would of been nice if there was a way in dos to add each line from the text file into just one line.
Thanks again. Atleast you have saved me having to type out all the file names :)
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #8 on: July 12, 2005, 09:12:52 am »
Download SimpleFileJoiner.exe.
Select all the files you want, select sort list (to make sure they're in alphabetical order), and select join.  Done!
vibez
« Reply #9 on: July 12, 2005, 10:32:16 am »
Thanks but i'm not sure how that would help. The program I'm writing the batch for converts multiple files into a different format then encrypts them all into a big file. I don't think a file joiner is the answer here.
Although it does look like it will come in handy for other projects :)
