Author Topic: Newbie Questions, help needed  (Read 1807 times)
ooby
  • Last login:December 27, 2005, 11:29:46 pm
« on: July 10, 2005, 07:40:58 pm »
Hi All,
I'm new to arcade cabinets and decided that I'd have to build one.  I want to build a 4 player control panel and this is giving me the most grief and confusion so if someone can answer my questions I'd be grateful.
1) What are the mandatory buttons that I need?  I know I'll need 4 x player buttons and 4 x coin buttons but what about action buttons?  I was thinking of 6 for player 1 and 2 and 4 buttons for players 3 and 4.   Is that enough?
2) Also do I need any extra control buttons?  Like an escape or pause button?
3) I was thinking about getting the joysticks from Happ controls.  Should I get 8 way or 4 way, or what about the ones that you can change?
I know these are probably pretty basic questions but thats the level I'm at.
starnix17
  • Last login:December 19, 2011, 11:00:29 am
Re: Newbie Questions, help needed
« Reply #1 on: July 10, 2005, 08:11:39 pm »
1. It depends.... a lot of older games use few buttons (I believe most use 2, but I'm not 100% sure). Newer games (fighting, etc.) usually use at least 4 buttons.
2. I'd put on a button to enter and escape a game, but you can use a combination of buttons like Player 1 quarter button + player 1 button to exit a game etc.
3. Once again it depends, if you like older games then go with a 4 way, if you play newer games then go with an 8 way. I've never played around with the ones that change so I can't tell you about them.
-Tony
daveg2000
  • Last login:January 02, 2009, 08:55:51 pm
  • PSP? Yeah right. GP2X Baby! This thing is awesome
    • www.davegrams.com
« Reply #2 on: July 10, 2005, 08:16:14 pm »
Extra buttons I have besides the normal ones for each player are:
3 mouse buttons, pause button, volume up, volume down button.
The rest of the commands (ESC, TAB, etc....) I have programmed
as multiple button presses throughout the control panel.
(which you can do with a keyboard encoder.. I use an IPAC4)
...so I will ask you... "Deal, or No Deal?"
ooby
« Reply #3 on: July 10, 2005, 08:32:40 pm »
Thanks guys.  I was planning on using the IPAC4.  Is it easy to wire up to do multiple button presses?
RTSDaddy2
  • Last login:April 03, 2014, 08:28:03 pm
  • Bees! Oh bother!
« Reply #4 on: July 11, 2005, 12:19:22 pm »
Not to oversimplify, but you will be amazed - AMAZED - at how easy it is to hook up the IPAC.  Man, I know zilch about electronics, but I got mine right on the first try.
Regarding switchable joysticks,  I suppose it's a matter of preference...I have Ultimarc's T-stick plus sticks in mine, which are switchable from the top and I love them!  So nice to not have to lift the panel top everytime!
At one point early on, however, I didn't have them put back together correctly (it was my fault, and it wasn't that hard a fix) and they would not switch from the top.  At the time I wasn't sure what was wrong with them, so I just switched them from underneath...and I found that NOT to be that big a deal either.
RichyRich
  • Last login:November 17, 2006, 12:22:40 am
  • If it ain't broke don't try and fix it
« Reply #5 on: July 11, 2005, 04:34:12 pm »
In your post you say 4xcoin buttons but I think I'm right in thinking you will only need 1 coin button.I'm sure others on here can clarify this.Good luck with your cab.
AlanS17
    • AlanS17
« Reply #6 on: July 11, 2005, 05:49:46 pm »
Nope, you'll need 4 coin buttons. In most 3 and 4 player games, you select your position on the control panel by dropping a coin into the proper slot. Each player has a dedicated coin slot. You'll need all 4 of them.
daveg2000
    • www.davegrams.com
« Reply #7 on: July 11, 2005, 09:43:08 pm »
I second that.. you will need 4.
ooby
« Reply #8 on: July 11, 2005, 11:29:58 pm »
Thanks for all the replies, all been helpful.  I know I'm getting the IPAC4 with either the Competition or Ultimate joysticks and buttons from Happ Controls and will order them tomorrow night.  Very exciting  :)
Anyone know how long they take to be delivered to Australia?
RichyRich
« Reply #9 on: July 12, 2005, 04:23:59 am »
Sorry, my mistake.Are there any 2 player games that require an individual coin slot for each player?
ooby,if you've got the money I would seriously consider getting the p360's and a dedicated 4way like the reunion or a wico.
« Last Edit: July 12, 2005, 04:25:38 am by RichyRich »
Tiger-Heli
    • Tiger-Heli
« Reply #10 on: July 12, 2005, 08:28:52 am »
I think so - Not sure which, but I'm pretty sure some of the 2P Simultaneous like CABAL and Twin Cobra use Coin 1 for extra life for Player 1 and Coin 2 for extra life for Player 2.
I could be wrong, though!!!
