Author Topic: Control panel getting loose (pics)  (Read 1385 times)
telengard
  • Last login:April 01, 2026, 04:20:10 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« on: July 10, 2005, 01:34:36 pm »
I have a metal control panel that is held down by 2 clamps and attaches w/ a flange type thing and screws to the cabinet itself.  This seems to be pretty standard from what I can tell.  The problem I'm having is that the panel tends to move a bit in the Y direction (the direction you would move a joystick up/down).  I have tightened everything down but nothing seems to help.  Maybe it's just slop w/ the clamps but I can't tell.  It's getting annoying.  I used some rubber washers to raise the cp a bit making the clamp a big tighter but it doesn't completely eliminate the issue.  I can post pictures if any of this is confusing.   :)
Anyone else experience this or possibly have an idea on how to combat it?
~telengard
« Last Edit: July 15, 2005, 07:07:10 pm by telengard »
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
SirPeale
  • Green Mountain Man
Re: Control panel getting loose
« Reply #1 on: July 10, 2005, 04:23:22 pm »
Take off either the clamp, or the clamp holder, and move it back a fraction of an inch to take up the slack?
NoOne=NBA=
« Reply #2 on: July 10, 2005, 04:55:00 pm »
Pics would probably help tailor suggestions to the specific panel in question.
telengard
    • S T U R C A D E
« Reply #3 on: July 14, 2005, 03:49:16 pm »
Ok, I've got some pics and hopefully they will help.
This is the panel when it is locked down:
Here are the right and left sides:
The rubber rings were an attempt to lift the panel up a little so the clamp would be more snug.  It worked but it has gotten loose again.  The main problem is that the panel slides towards the player when pulling down on a joystick.
Here is how the clamp attaches to the panel:
I can take more if necessary...
~telengard
