Author Topic: monitor problem  (Read 1150 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
monitor problem
« on: July 10, 2005, 05:48:34 am »
ok im just going to clarify this with some of the techs here...when there is a color missing from the monitor completely that means it needs a cap kirt right? cause if its like the tube i can change that and even if its the caps i can change that but i just want to be sure...its a wells gardner model too.
SirPeale
  • Green Mountain Man
Re: monitor problem
« Reply #1 on: July 10, 2005, 09:28:55 am »
Maybe a cap problem, but one of the color transistors may have died.
Ken Layton
  • Guru
  • Technician
Re: monitor problem
« Reply #2 on: July 10, 2005, 12:03:19 pm »
Missing a particular colr generally would be either a bad transistor on the neckboard, bad color adjustment pot on the neckboard, one of the large resistors on neckboard, or a bad picture tube. Usually a capkit is what I always do first to rule out the possibility of a bad cap.
