May 13, 2026, 08:38:29 pm
Quote from: mikepaktinat Any ideas?Haven't had that problem, but you can setup a global config file to use as a default mapping across all of mame[32]. They're under Mame32's ctrlr directory. You can create your own 'GamePad' folder with a 'default.ini' in there.
Any ideas?
see.. on the CD they are set to read only typically.. so if you copy the file from the CD to your HD.. it too could be read-only..
