Author Topic: What is this?  (Read 2631 times)
Big Ben
  • Last login:July 15, 2005, 11:56:04 am
  • don vito, why?
    • Project Funbox
What is this?
« on: June 30, 2005, 09:37:26 pm »
When I was looking through my broken MKII machinen i found a small rectangulat prism type thing in the base of the coin collector. I am assuming that it is some kind of counter b/c it has mechanical digits on it that look like it has somethign to do with the coins. And of course it has teo wires connected to it. Help please.
Thanks,
BB
I want some jamatizable cabinets in the southeast.
                               C'mon people.
Captain_Dingo
  • Last login:November 28, 2018, 05:57:32 pm
Re: What is this?
« Reply #1 on: June 30, 2005, 09:40:40 pm »
Thanks,
BB
It's an odometer.  It measures how far your cabinet has moved since it left the factory, by using the GPS receiver mounted behind the marquee.  If you move your cabinet around the house for a while, you'll see the digits incrementing.
Seriously, you hit it on the head.  It counts the number of times the machine is played.
Big Ben
  • don vito, why?
    • Project Funbox
Re: What is this?
« Reply #2 on: June 30, 2005, 09:48:04 pm »
Ah thank you. That isn't one of the most useless things in the world. How much do they cost?
                               C'mon people.
flampoo
  • Last login:March 20, 2014, 11:41:07 am
  • BYObsession
    • flampoo
Re: What is this?
« Reply #3 on: June 30, 2005, 10:17:20 pm »
They're referred to as meters and they're fairly inexpensive. A new replacement shouldn't cost more than $7.
http://www.happcontrols.com/cc/meters.htm
« Last Edit: June 30, 2005, 10:19:01 pm by flampoo »
thetered
  • Last login:April 12, 2011, 02:29:57 am
  • Dirty!
Re: What is this?
« Reply #4 on: July 01, 2005, 01:25:15 am »
They had tons of purposes for arcade owners and such who wanted to track what games were popular and such, and see which ones had to go.  I worked at an arcade a while back and it was easier to read that than to count the quarters which we just tossed in bags with quarters from all the other machines.
Avery
  • Last login:May 03, 2013, 12:52:02 am
  • Have fun! Make stuff.
Re: What is this?
« Reply #5 on: July 01, 2005, 08:50:28 am »
Or to be able to tell if someone in the staff was skimming the take.
Avery
Captain_Dingo
Re: What is this?
« Reply #6 on: July 01, 2005, 12:39:46 pm »
Not always... :)
I knew a guy that worked at an amusement park arcade once summer.  He'd disconnect the meter in the morning, then go back and clean out the cash box around lunchtime and reconnect the meter.  By the end of the day, the meter would match the count in the coinbox, and by the end of the summer, this guy had a ton of quarters...
Avery
Re: What is this?
« Reply #7 on: July 01, 2005, 01:51:01 pm »
They say prisons aren't full of criminals, they're full of stupid criminals.  ;)
Avery
