Author Topic: Question on Mamewah + Jukebox player  (Read 2171 times)
pacman
  • Last login:October 01, 2007, 09:51:35 am
« on: June 30, 2005, 09:13:56 am »
I am using Mamewah on my cab and would like also to use the Arcade Music Box player. AMB will be launched from Mamewah as an external application but then once I want to go back in Mamewah how do I do ? If I quit AMB I will get to the XP desktop instead of Mamewah. Is there a bat file to create ?   ??? ???
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
Re: Question on Mamewah + Jukebox player
« Reply #1 on: June 30, 2005, 12:15:03 pm »
Exit AMB and control is returned back to Mamewah.  Nothing special to do, as far as I remember.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #2 on: June 30, 2005, 01:39:20 pm »
yep, Zaphod has right (hey Zaphod, great to seeing you).
It autoresume resume to mamewah, when quitting. You may need to use the safe feature when running, if it got problems to get back to Mamewah...
But, Pacman, please test this:
 - Do mamewah quit auto, when AMB and mamewah use the same quit key?
 - Do it return to mamewah, if you have used a another quit key in amb (quit, using control panel is a safe way)?
Maybe I forgot to wait a keyrelease when quiting in v2.03 (Mamewah should doing that too, not all emalators may doing that)?
« Last Edit: June 30, 2005, 01:43:08 pm by Space Fractal / Denmark »
pacman
« Reply #3 on: June 30, 2005, 05:11:45 pm »
OK I will try this tonight and report you back... ;) ;)
pacman
« Reply #4 on: July 01, 2005, 03:12:10 am »
I have tried 2 different settings :
- the first one in the mamewah ini where I set up AMB as an application to be launched after quitting mamewah
Result: AMB is launched from the mamewah selection menu but when I quit AMB, XP just rolls me back on the desktop...
- Second one in the Mame ini file where I set up the external application to be launched (only the executable, I did not set up the comandline format) and I got an error message when launching AMB... ??? ::)
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #5 on: July 01, 2005, 08:11:36 am »
this ini file works fine on my arcade machine (create a shourtcut in the main amb dir, and point it to the exe file in the bin dir. Rememver to change rom_path, because it use a danish path):
### jukebox.ini (mamewah v1.60) ###
emulator_title                            Arcade Music Box
### List Generation Settings ###
rom_path                                  C:\Programmer\Arcade Music Box 2
rom_extension                             lnk
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       PC
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
mouse_cursor                              none
### Artwork Locations ###
artwork_1_image_path
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
play_music_during_emulation               0
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
