Author Topic: Ok - any way of getting mame to run on arcade monitor without ArcadeVGA?  (Read 1398 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
my arcadevga card i received from ultimarc was faulty so it's gone back.  i've tried powerstrip and because my graphics card is a basic one the custom resolution settings arent available (the option is greyed out and unclickable).
is there a way of getting mame to run on my arcade monitor (via the jpac) without using an arcadevga card? i've tried booting my pc straight into a dos command prompt after xp loads but still the display on the arcade monitor is crap.
thanks in advance for any input!
eggedd2k
just had a thought - would dos machine work without an arcadevga card?
TheVengeance
  • Banned
  • Last login:October 19, 2005, 05:31:38 pm
  • Banned
Yes it would, depending on your card. You could try having a look around here.
http://www.msu.edu/user/jonesdes/easycab.htm
He offers many different configurations for DOS and arcade monitors. Very easy to setup also.
**EDIT** I believe he is also a member of the forum, although right off hand I can't think of his name.
Banned
MonitorGuru
AdvanceMame with pure DOS (nothing after Win98SE) or Linux will work with most all video cards, except many on-board only videos, and drive an arcade monitor perfectly with a little configuration.
eggedd2k
my computer has got on-board video.
will a computer that boots straight into a game work with standard mame?
eggedd2k
when connected to an arcade monitor without arcadevga?
Raven..
  • Last login:June 29, 2021, 12:51:50 am
I've never used an arcadeVGA card.  I use DOSfrom 98SE and AdvanceMAME.  Works great, and it may work with your on-board video.  (depends on the chip it's based on).
TheVengeance
  • Banned
  • Banned
Banned
