Author Topic: i'm looking for good molex type connectors for control panel?  (Read 1317 times)
thetered
  • Last login:April 12, 2011, 02:29:57 am
  • Dirty!
I'm trying to find a suitable connector for my control panel so I can swap CP's back and forth, does anyone know of any good ones that have atleast 12 pins each?
Tailgunner
Re: i'm looking for good molex type connectors for control panel?
« Reply #1 on: June 26, 2005, 02:32:23 am »
AMP Mate N Lock connectors would do nicely. Bob Roberts has them as they've been used in quite a few arcade machines.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: June 26, 2005, 12:30:07 pm »
I disagree completely on using AMP brand products. They are only resaonably priced if you are a manufacturer and buying their products in 100,000 quantities. For the average Joe AMP products are way way overpriced. I refuse to buy their stuff.
Go to mouser.com and buy Molex stuff instead. It's a lot cheaper.
Mouser part numbers:
538-03-09-1125 Receptacle, 12 pin, .093" (59 cents each)
538-03-09-2122 Plug, 12 pin, .093" (45 cents each)
538-02-09-1119 Female terminal, .093" (8 cents each per 100)
538-02-09-2118 Male terminal, .093" (10 cents eac per 100)
thetered
  • Dirty!
« Reply #3 on: June 26, 2005, 01:39:32 pm »
Thanks for the info, those are what I was looking for, but I wanted to see a picture to be sure and I found them over at www.jameco.com and they were quite a bit cheaper, on my order I saved a little over 10 bucks verses mouser.   Just thought you might be interested for future reference.
