Author Topic: wrong size t-molding  (Read 1414 times)
dogg0
  • Last login:December 14, 2014, 01:18:29 pm
  • ALL? no ALL!!!
« on: June 22, 2005, 09:26:45 am »
I am building a cab for friend with mostly spare parts. Buying new t-molding is not really an option, I would rather just round the edges with a router. So... here is the problem. I made the sides of the cab from wood that is 5/8" thick (I got it for free!), and I have a lot of 3/4" t-molding lying around. Anyone ever trim the t-molding to fit 5/8" wood? Any ideas to fit it on there?
thou shalt not supress flatulence
-the bassmaster general
Stingray
Re: wrong size t-molding
« Reply #1 on: June 22, 2005, 10:17:24 am »
Here's what I would try. Put the tmolding on before you paint. Use the edge of the wood as a guide and trim the excess off with a razor. Then remove the t-molding & paint. Never done this mind you, I'm only saying what I would try.
-S
dogg0
  • ALL? no ALL!!!
« Reply #2 on: June 22, 2005, 11:51:13 am »
I'll try it! (on a small peice of wood first)
rdagger
« Reply #3 on: June 22, 2005, 11:54:44 am »
A flush trim router might work better to trim the necessary 1/16th" from each side.
