Author Topic: WG 9200 Help - Whites have turned Gray  (Read 1537 times)
poncho13
  • Last login:July 05, 2005, 07:23:16 pm
« on: June 21, 2005, 08:12:38 pm »
All the whites on my WG 9200 recently turned into a grayish color.   Adjusting the brightest or contrast setting has not helped.   Any ideas on what the problem could be?  Using a ArcadeVGA Card.
I've swapped out the cable with no change.   Also, the "out of signal" screen seems to be perfect in terms of colors.
Thanks for the advice.
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
Re: WG 9200 Help - Whites have turned Gray
« Reply #1 on: June 23, 2005, 06:05:25 pm »
Couple of my PC monitors have a setup option for video level - either 0.7 or 1 volt - if its on 1 volt, everything is grey and weak looking. Got anything similar on the 9200?
