Poll
Topfire or Trigger fire Joysticks...
Topfire
Trigger Fire
Author Topic: Topfire vs. Trigger...Need some opinions...  (Read 7586 times)
whammoed
  • Last login:March 13, 2026, 12:48:37 pm
  • Crack don't smoke itself
    • NiceMite
Re: Topfire vs. Trigger...Need some opinions...
« Reply #40 on: June 23, 2005, 07:46:14 pm »
SlikStik supposedly has an anti spin mechanism for their new lighted ball top sticks but unfortunately they aren't available yet. :-\
conseit68
  • Will sell anything that isn't nailed down...
  • Last login:February 12, 2020, 10:52:27 pm
  • Back to the Future Cab...In Progress
« Reply #41 on: June 24, 2005, 09:23:36 am »
I tore apart the CP of my Xmen 6 Player last night and noticed that the joys there used a rubber grommet also to prevent "twisting". hmmmmmmmm
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #42 on: June 27, 2005, 05:01:31 pm »
Co-incidence?  I think Christian said the anti-spin was the part they were still working out.
Posted by: conseit68      Posted on: June 24, 2005, 12:23:36 PM
The sticks inside your 6p X-Men should be regular Wico grommet sticks.  The grommets only prevent twisting when they're rusted to the handle.  That's not uncommon, but it's also not desirable because you can't dis-assemble the stick if the grommet is stuck on the shaft.
The "nub" method should work well for grommet sticks (Wico, Happ 49).  You'd only have to modify the grommet.
Spring sticks (Super, Competition, P360, Reunion) don't have anything at the pivot point to work with.   I don't see any way to prevent rotation without modification of the base itself, unless you wanted to produce some other pieces that would bolt on to the base, and those would add cost.
« Last Edit: March 01, 2006, 12:49:02 am by Kremmit »
specfire
  • Last login:March 21, 2026, 04:58:37 pm
  • Shhh...
« Reply #43 on: February 28, 2006, 02:24:34 pm »
BUMP
Just for completeness, I thought I would bump the other thread related to the "Topfire Ball/Battops..." thread that Allister Fiend has just bumped.
These should have been one thread to begin with.
FWIW, I still vote for a Tron Trigger cocktail stick.
specfire
Read to your kids, you'll all be better for it.
