Author Topic: No wires connected to Red Green Blue on jamma connector  (Read 1623 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: June 20, 2005, 04:02:06 pm »
i was just looking at the pinouts for a jamma edge connector and on my jamma edge connector there is nothing connected to the Red Green and Blue connectors.
is this normal?
AlanS17
    • AlanS17
Re: No wires connected to Red Green Blue on jamma connector
« Reply #1 on: June 20, 2005, 04:04:49 pm »
That depends... is it working?  ;)
Then what's going out to the monitor?
Ken Layton
  • Guru
  • Technician
« Reply #2 on: June 20, 2005, 06:14:09 pm »
Name of game?
Dedicated or conversion?
Make of cabinet?
Make & model of monitor?
Was it working before?
eggedd2k
« Reply #3 on: June 21, 2005, 10:03:45 am »
yep all colours on screen are fine.  the game's Zero Wing and the cabinet is a generic Video Master cab.
I hope everything is ok coz i've just ordered a jpac and arcade vga card.
eggedd2k
« Reply #4 on: June 21, 2005, 10:04:29 am »
by the way the game board does say jamma on it
eggedd2k
« Reply #5 on: June 21, 2005, 10:34:03 am »
presumably it must be wired up correctly (to the jamma standard) if it's working properly?
i'll have to have a nother look at it tonight and take a photo if neccessary. i dont see how it could work if it's not wired up right
Ken Layton
  • Guru
  • Technician
« Reply #6 on: June 21, 2005, 11:05:25 am »
Why not follow the video connector wires from the monitor back to the board?
eggedd2k
« Reply #7 on: June 21, 2005, 11:08:35 am »
i'm going to. what if they connect somewhere different on the jamma connector? :o :o
AlanS17
    • AlanS17
« Reply #8 on: June 21, 2005, 02:22:45 pm »
That's highly unlikely. It would defeat the purpose of being a JAMMA game.
This might sound like a dumb quesiton, but... are you sure you're looking at the right side of the edge connector? After all, there's a component side and a solder side. If it's not labeled on the harness, you can tell by the "key". The key is the plastic piece on the harness that only let's you install it one way. Are you sure it's not just wired fine and you just have everything flip-flopped in your head?
eggedd2k
« Reply #9 on: June 21, 2005, 04:38:02 pm »
i can confirm the wires ARE connected to the correct video inputs.  I was obviously looking/counting wrong last night. ::)
i open myself up now for some p1sstaking.. ;D
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #10 on: June 21, 2005, 10:00:11 pm »
Ray B smacks Eggguy
NO MORE!!
62impala
  • Last login:July 25, 2005, 08:29:35 am
  • 62 Impala
« Reply #11 on: June 25, 2005, 09:00:37 am »
DOH!
Franco
« Reply #12 on: June 26, 2005, 05:44:19 pm »
Ha ha, interesting 1st post!
Heres another:
Just found out that Doh! is in the Oxford English Dictionary (OED)!
Quote:
"Expressing frustration at the realization that things have turned out badly or not as planned, or that one has just said or done something foolish. Also (usually mildly derogative): implying that another person has said or done something foolish.
:end quote
Yep, about sums it up really  ;)
