Author Topic: Need to connect PC to Gauntlet Legends monitor  (Read 2907 times)
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
« on: June 20, 2005, 01:14:26 pm »
I've got a Gauntlet Legends cabinet with 12 play hours on it!!! I want to mame it (without destroying the original parts)...and the part I need to figure out is how to hook into the monitor.
I believe it says K7500 on it. It's a 27" medium resolution.
Any ideas? I was thinking about ArcadeVGA...but I've never used one (always used big computer monitors).
Thanks, -Aaron
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
AlanS17
    • AlanS17
Re: Need to connect PC to Gauntlet Legends monitor
« Reply #1 on: June 20, 2005, 01:26:28 pm »
Do you plan on continuing to play the Gauntlet Legends?
soslo
  • The Governator
« Reply #2 on: June 20, 2005, 03:44:11 pm »
Not at the moment...unless there is an easy way to switch the sound/video/controls easily...
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« Reply #3 on: June 20, 2005, 03:59:54 pm »
i believe an arcade vga will do the trick
AlanS17
    • AlanS17
« Reply #4 on: June 20, 2005, 04:03:58 pm »
If you're not going to be playing the game, the monitor ought to have mode switching. Most med res monitors I've seen are able to switch back to standard res. Then it'll work just as you'd expect any other standard res monitor to. Without more details on the monitor, though, I couldn't tell you how to go about doing that.
soslo
  • The Governator
« Reply #5 on: June 20, 2005, 04:23:08 pm »
It's a Wells Gardner 27K7501, 27" 25Khz medium resolution.
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #6 on: June 20, 2005, 10:45:13 pm »
The arcadevga will not work with a medium resolution monitor.  The modes built into the arcadevga are for a standard res monitors.  If it has mode switching as AlanS suggested then you could go that route.  The gauntlet legends board is capable of outputting standard, medium, and vga modes so you could still play the original game regardless of what resolution the monitor is set to.  If it doesn't have mode switching then you will have to use advancemame or you could buy the video converter from happs.  I have heard the quality is good but it is around $200 though(and I think it is made by ultracade  :P).
Raven..
  • Last login:June 29, 2021, 12:51:50 am
« Reply #7 on: June 21, 2005, 12:35:13 am »
Forget the AradeVGA card.
« Last Edit: June 21, 2005, 12:47:32 am by EyeDoc »
