Author Topic: WG D9200 Which One?  (Read 1737 times)
ITrek
  • Last login:January 06, 2009, 10:18:26 pm
WG D9200 Which One?
« on: December 13, 2002, 10:31:51 am »
I'm going to order a WG9200 but their web site has 2 D9200's listed:
27 Inch D9200 Digital Control Monitor Identifier:  WGM2792-U0TS42A
and
27" D9200 DIGITAL CLR MON HORIZONTAL  Identifier: WGM2792-H0TS59L
Does anyone know the difference between these two?
Also, is there a less expensive distributor or do you get the best price by buying directly from WG?
What would happen if the whole world farted at the same time?
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
Re:WG D9200 Which One?
« Reply #1 on: December 13, 2002, 10:50:22 am »
I believe the difference is in how they mount..  I've been checking them out also
WGM2792-U0TS42A
that means universal mount
WGM2792-H0TS59L
that means horizontal mount
Let me dig up something more solid for you :)
Silverwind
« Reply #2 on: December 13, 2002, 10:54:48 am »
From http://www.wellsgardner.com/wellsgardner31/catalog.cfm?dest=itempg&itemid=912&secid=18&linkon=section&linkid=18
HORIZONTAL MOUNT:
 This is a mounting scheme whereby the picture tube is in the horizontal position. There are two side brackets with handles in them that the picture tube mounts to with four screws.
UNIVERSAL MOUNT:
 Universal mount monitors can be mounted in different configurations. There is a bracket on the top and one on the bottom of the picture tube. There are two "U" channel brackets that can be mounted in differen5 positions ion the top and bottom brackets.
Additionally,
http://www.wellsgardner.com/wellsgardner31/supportdata/RELEASE%20NO%20BREAKDOWN.ppt
that will show you how to break down the wells-gardner part number.
It looks like the 9200 they show in the picture is the universal mount (if you look there are brackets on top and bottom).  I don't believe they offer a vertical mount for this model.  Hope this helps.
« Last Edit: December 13, 2002, 10:59:38 am by Silverwind »
