Author Topic: what does it mean !  (Read 2396 times)
jesterboy
  • Last login:June 27, 2005, 07:31:59 pm
what does it mean !
« on: June 19, 2005, 09:17:33 pm »
when I hit start-run regsvr32.exe paintx.dll a dialog box comes up saying" dll register server in paintx.dll is succeeded" what does this mean  :-[
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re: what does it mean !
« Reply #1 on: June 19, 2005, 09:23:48 pm »
I don't know, but you might want to read this thread:
http://forum.arcadecontrols.com/index.php/topic,24993.0.html
jesterboy
« Reply #2 on: June 19, 2005, 09:58:57 pm »
Well the person in question seemed to have solved his problem....... However it would have been nice if he said how he done it !
  • Last login:March 28, 2026, 02:54:37 pm
« Reply #3 on: June 20, 2005, 03:14:38 am »
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #4 on: June 20, 2005, 04:13:08 am »
regsvr32 is used to register COM objects.  COM is the Microsoft's Commun Object Model. Windows was (and is still even if .NET  is beginning to change that) based on this model.
a COM component can be used by windows applications, the Application can instanciate (create) the component and use it to call Method by quering Interfaces First. The call of a COM component is normalized.
To be able to call a COM Component, it need to be registered in the system. It is not enough to have the file on your Drive.  To register the component in the system you use the utility Regsvr32  following by the name of the file where is stored the component (generaly a .DLL , but i could be a .OCX) . RegSrvr32 will write for you needed information in the windows registry.  Then Application will be able to use the component.
PaintX.dll seems simply to be a component you need to register. The message you read means "Now , the component is ready to use!"
COM object are very Similar to ActiveX  (ActiveX is based on COM) , ActiveX component are register in the same way.  Usually application you install did the registration for you  in Silent Mode, so you are not aware of what happens.
jcrouse
    • CPViewer
« Reply #5 on: June 20, 2005, 03:57:14 pm »
« Reply #6 on: June 23, 2005, 05:22:02 pm »
AlanS17
    • AlanS17
« Reply #7 on: June 23, 2005, 05:34:39 pm »
Yeah if that's the reply you got from HC that means you caught him on a good day.  ;)
