Author Topic: noob question. (be gentle)...  (Read 985 times)
vornar
  • Last login:July 05, 2008, 12:48:31 am
« on: June 16, 2005, 07:37:35 am »
Hi guys, i have a couple of questions that i need some help with. I am designing a two player fighter layout with an extra 4 way stick and a trackball. I'm still at the part collecting stage.
My question is whether or not i can connect a 4 way stick to an ipac2 as well as an 8 way on the same inputs or do i have to buy an ipac4 and connect them as player 3 and change the game inputs individually inside mame.
Lilwolf
Re: noob question. (be gentle)...
« Reply #1 on: June 16, 2005, 08:10:07 am »
Let me be as gentle as possible
Baby Bunnies
Pillow
New Down Feather Pillow (freashly fluffed)
Pillow
Kittens
Fluffy Kittens
Pillow
Ok, and to your question.
Yes.  But you have to be careful.  I had this on my first control panel.  And when I played with some friends... if I had them stunned... they would drop their controller and grab the 4 way to mess up my super upper cut kill finish move.  Then I would have to push him over to and get back to my controller... IE turned it into a physical sport.
What you might consider doing is having a switch (dual would be best) that would break the ground wires used in the 4way or the 8way.  So the ground is only connected to one of the two at a time.  Then flipping the switch will change the joystick which is accessable.
If you don't understand the wiring, let me/us know.  I/Someone can draw a quick example in MSPaint for you.
vornar
« Reply #2 on: June 16, 2005, 08:22:57 am »
Thanks Lilwolf, top idea...
skarr
  • Last login:April 06, 2010, 11:00:23 am
  • BYOAC newbie
« Reply #3 on: June 16, 2005, 09:06:47 am »
WTB Paint example :)
