Author Topic: BuddaMAME v0.97 released  (Read 1961 times)
Buddabing
« on: June 15, 2005, 12:20:48 pm »
Download the binary here.
I've included some extra prebuilt binaries.
cpmaker.exe - generates controls artwork if you want to use a different version of mame.
ledmovie.exe - generates an AVI (xvid format only at this time) which will show your control panel playing animations. I'm working on updating my artwork library with images of lit-up buttons.
animaker.exe - animation compiler, takes animations written in my animation language and turns them into a file that can be loaded into my LED controller.
If you want to compile your own executable, you'll need:
CPMaker library code
ImageMagick library code
Please read the wiki!
darktemp
  • Last login:July 20, 2006, 11:18:39 pm
  • Rumbler
Re: BuddaMAME v0.97 released
« Reply #1 on: June 15, 2005, 06:09:27 pm »
Hi Buddabing, just downloaded all the new files and created a fresh source directory and I get the same error compiling.
Compiling src/cpmaker/libs/magick/string.c...
Compiling src/cpmaker/libs/magick/geometry.c...
Compiling src/cpmaker/libs/magick/hashmap.c...
Compiling src/cpmaker/libs/magick/memory.c...
Compiling src/cpmaker/libs/magick/token.c...
Compiling src/cpmaker/libs/magick/image.c...
Compiling src/cpmaker/libs/magick/random.c...
Compiling src/cpmaker/libs/magick/utility.c...
Compiling src/cpmaker/libs/magick/cache.c...
src/cpmaker/libs/magick/cache.c:59:18: zlib.h: No such file or directory
mingw32-make: *** [obj/mame/cpmaker/libs/magick/cache.o] Error 1
I didn't have to mess with any files and I left the makefile alone which looked correct and it compiled well all the way to cache.c again.  I'm sure this is something I'm doing wrong because I've never compiled before but I can't figure this one out.
SirPoonga
  • Puck'em Up
  • Last login:Yesterday at 08:28:46 pm
  • The Bears Still Suck!
« Reply #2 on: June 15, 2005, 07:04:45 pm »
when you going to rename, or do you have permission to use MAME?
I suggest BuddaAME.  Budda Arcade Machine Emulator :)
Buddabing
« Reply #3 on: June 15, 2005, 07:54:18 pm »
I suggest BuddaAME.
Buddabing
« Reply #4 on: June 15, 2005, 07:58:39 pm »
darktemp
  • Rumbler
« Reply #5 on: June 21, 2005, 03:52:58 am »
That did it!  Thanks Buddabing and great work.
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #6 on: June 21, 2005, 09:40:39 am »
I was thinking BLAME.
BLAME sounds bad in french...  and in english too i think...
I put the blame on you for using BLAME...  ;D  ;)
papercut
  • Last login:August 31, 2006, 10:38:55 pm
« Reply #7 on: June 21, 2005, 04:39:40 pm »
It's a departure from BuddaMame but... I was toying with this for another thread but decided to bring it here....
How about FOLEY
Fully Open LED Emulator (of) Yesteryear.
And be sure to trademark the name.  :angel:
Buddabing
« Reply #8 on: June 22, 2005, 02:20:24 pm »
I've uploaded new example files, layouts, and images.
Images
Examples
How about BLING for the emulator name? After all, that's what most of my extensions are all about!
All I need now is a suitable acronym.
Buddabing's LED Is No Good
That doesn't work very well..........
