Author Topic: Topfire Ball/Battops...  (Read 20340 times)
whammoed
  • Last login:Yesterday at 12:15:06 pm
  • Crack don't smoke itself
    • NiceMite
Re: Topfire Ball/Battops...
« Reply #80 on: August 02, 2005, 10:12:25 am »
Regarding the stick spinning and twisting the wires:
Don't know if you noticed how slik stik solved the problem but instead of keeping the handle from spinning they used an audio jack and cable that allows the stick to spin freely but not twist the wires.  Heres the pic.  You might consider something similar.  Seems like it would be cheaper, easier, and work for all joystick bases obviously.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #81 on: August 02, 2005, 10:28:05 pm »
WHAT A NOVEL IDEA!!!!!!!!!! DANG I should do that too with mine!
 :o
NO MORE!!
conseit68
  • Will sell anything that isn't nailed down...
  • Last login:February 12, 2020, 10:52:27 pm
  • Back to the Future Cab...In Progress
« Reply #82 on: August 03, 2005, 02:38:43 pm »
genius whammo...your my new best friend...  :laugh:
thank you for posting those...back to work i go...
Franco...Markrvp...you guys getting this?...
whammoed
    • NiceMite
« Reply #83 on: August 03, 2005, 03:56:08 pm »
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #84 on: August 03, 2005, 09:00:36 pm »
Looks like a good solution.  All you need is a mono 1/8" jack.  Then you can get a 1/8" cable with plug and cut off the end you don't need.  Then just run those to your encoder (1 wire is ground, the other goes to the correct input).
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
« Reply #85 on: August 11, 2005, 12:58:03 am »
They are obviously using the 4 position 2.5mm sockets like nokias have for headsets, I guess if you used the same plug you could have both 2 colours of illumination and the button or multiple buttons if you were to put a flightstick type control on (ooooooh hatswitch ;)
slayj
  • Last login:January 10, 2006, 02:49:56 pm
  • Anybody seen my joy...???!
« Reply #86 on: August 24, 2005, 01:08:50 pm »
Any new news guys..............?????
Did you know if a frog had wings it wouldnt bump its butt!!!
AllisterFiend
  • Last login:June 04, 2013, 05:04:16 am
  • Rush 2112
    • Check out my Dragon's Lair/MAME cabinet.
« Reply #87 on: February 27, 2006, 10:14:54 pm »
BUMP!!!
Anyone still looking into this?
I know this is an old thread but I see all these new products coming out but no one seems to be tackling this one.  Am I the only one out there who thinks there needs to be a better topfire joystick than the one that happs sells.  It's awful looking and does not even fit in with my control panel.
It would be nice to see RandyT incorporate a topfire into his GPWiz49 joystick.
Hint, Hint ;D, You have 4 sold already if you decide to market one.
Allister Fiend
