Author Topic: Image has split on 19" k7000  (Read 1402 times)
menace
« on: June 13, 2005, 12:34:51 pm »
I recently fired up what I thought was a good working k7000 only to discover that the image had split horizontally.  think of the picture as being drawn on two combs with their teeth facing--it looks like the combs have pulled apart, leaving a duplicate image with solid overlapping areas.  I thought maybe the sync was off so i tested with H- and V- tied, and then separate--no difference.  Any thoughts?
I was using a known good jamma board to test with.
Ken Layton
  • Guru
  • Technician
Re: Image has split on 19" k7000
« Reply #1 on: June 14, 2005, 12:25:28 am »
Either the horizontal hold control is way out of adjustment, the monitor needs a capkit, or you have a medium res version being used with a standard res signal.
menace
« Reply #2 on: June 14, 2005, 07:22:18 am »
Thanks ken, I'm pretty sure is a standard res monitor (at least outwardly it looks like one--is there a particular component that would be a dead giveaway in this?)  I will have a look at the horizontal hold pot and eventually get around to doing a cap kit on it..
Gareth712
  • Last login:July 04, 2005, 01:18:42 pm
« Reply #3 on: June 16, 2005, 01:32:51 pm »
Are you sure it's not a Med res? it sounds like you have the same monitor thats in my APB cab and that runs med res.
