Author Topic: How Do You Increase The Resolution Without Losing The Quality?  (Read 2605 times)
M.A.M.E Power
  • Last login:February 06, 2007, 04:25:59 pm
  • There Are So Many Games!
Hey Guys
I think I have settled for a theme for my cabinet (transformers), I have searched the net and found some cracking images, the highest resolution I have is 1600x1200 but some of them are much lower (due to there size I think).
Is it right to assume if the resolution is low the larger you make it the more distorted it will look? I want the image as crisp as possible so do not want to lose any of the detail, I will be using the images for side art, control panel, monitor bezel, marquee  and perhaps the kick plate.
Can someone please tell me the BEST way to increase the resolution without losing any detail?
I think I am going to call the cabinet Transformercade what do you all think?
Thanks in advance
Lea ???
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
Re: How Do You Increase The Resolution Without Losing The Quality?
« Reply #1 on: June 11, 2005, 09:03:17 pm »
In a technical sense, there is no way to increase a low-res raster image to a high-res raster image without losing detail.
That's why so many arcade art projects incorporate vector images, as they can be resized with no loss of quality. But in their case it takes far more effort to create them.
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #2 on: June 11, 2005, 10:49:37 pm »
He's right. Low-res art will just not be suitable if blown up very much. On the bright side, I would think that as far as vectorizations go, most Transformer work should be fairly easy.
M.A.M.E Power
« Reply #3 on: June 12, 2005, 06:03:06 am »
Thanks for that guys, thought just as much will put them into illustrator and see what I can do!
M.A.M.E Power
« Reply #4 on: June 12, 2005, 07:03:56 am »
Can anyone supply me with a decent tutorial on how to vectorize images, I have both illustrator and PS but have been told that illustrator produces more accurate vector images. I have jpeg images at the moment which I believe are in raster format (this is all new to me).
Any help is appreciated as I really want to produce some great vector images.
Lea
Teknique
  • Last login:October 02, 2015, 10:35:46 am
  • I'm a Gauntlet wizard in real life
« Reply #5 on: June 12, 2005, 07:35:55 am »
Don't tell us you stole the programs or anything :) ......
Tutorial:
http://www.arcadecontrols.com/files/Miscellaneous/VectorTutorial_v1_3.zip
Tek
Your screen name has been added to my frag list.
M.A.M.E Power
« Reply #6 on: June 12, 2005, 07:49:08 am »
lol, the programmes came pre-installed on my computer when I purchased it. I have had it for 7 months and have never given them any notice until I started thinking about constructing my own cabinet.
Honest! :D
AmericanDemon
  • Last login:February 27, 2026, 01:01:31 am
  • Still an AmericanDemon
« Reply #7 on: June 12, 2005, 02:54:25 pm »
MAME Power, I am also building a Transformers based cabinet.  Its called the Optimus Prime Experiment.  I've contracted Felsir to work on some images for me.  Good luck on your project.
www.arcadeevolution.com/americandemon
