Author Topic: GeForce4 MX420 - Need help!  (Read 11054 times)
gajaman
  • Last login:July 19, 2011, 02:50:33 pm
  • The GajaCab is here......
    • The Gaja Project
« on: May 05, 2002, 09:58:58 am »
I bought a new PC today for my cab (nearly there!).
Couldn't get a reasonably priced machine with the ATI card I wanted so I settled for the GeForce4 MX420.
Problem is I cant get the PC the recognise the TV.
The PC came with no lead for the TV out so I bought a cheap s-video to scart - nothing. I've tried everything I can to get the pc to see it but it wont. The only input I have to my TV is scart and the only output on the pc is s-video, I thought the most direct route would be best, but apparantly not!
nVidia's website mentions buying an s-video to composite adapter if the TV has no s-video but nothing about scart. Has anyone successfully connected this card directly through scart?
The PC runs XP (not for much longer!!) and is a P4 2ghz.
Apols for keep asking tv out related questions, but this is causing by far the most probs for me.
mattv
  • Last login:June 10, 2022, 06:33:25 am
Re: GeForce4 MX420 - Need help!
« Reply #1 on: May 05, 2002, 02:14:17 pm »
Are you sure the T.V. out actualy works at all?
It might be a good idea to cart your computer around to a friend who does have an s-vid T.V. and check it out there before dropping more money on new connectors.
Also, if you haven't already installed the latest drivers for the card this would be a good time to do so.
tetsu96
  • Last login:September 06, 2024, 12:00:03 pm
  • MAME On...
    • My Old Cabinet / MAME32 build site
« Reply #2 on: May 05, 2002, 05:44:05 pm »
The GFX card needs to be receiving a certain signal from the TV before it will allow you to chose TV out as an option.  I had a GeForce2 which would recognise 1 of 2 TVs using the S-Video, but would work Composite with both.
I bought a scan converter anyway and it worked fine on both then...   ;D
