Author Topic: D9200 case shape  (Read 1759 times)
Bones
  • [Moderator]
D9200 case shape
« on: June 11, 2005, 12:43:25 am »
I am finalising some important cab dimensions and I am unsure about the case shape of the D9200. Refer to the coloured circles on my pic.
If this monitor was put on a flat surface, what part of the case would it naturally sit on?
Apologies for the obvious newb question but I have never seen one in the flesh. I was hoping to find my answer here http://www.retroblast.com/reviews/d9200-1.html but the case shape of this appears different.
« Last Edit: June 11, 2005, 04:03:22 am by BrokenBones1 »
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
Re: D9200 case shape
« Reply #1 on: June 13, 2005, 11:37:06 am »
The red part. I mounted mine in a monitor board. Just take plywood cut it to size and cut a hole for the tube fit though. Then drill holes where the mounting holes are on the monitor and bolt it to it. I then have two boards mounted to the sides of my cab so the monitor rests on them.
That way the whole monitor is off the ground.
Gary
Bones
  • [Moderator]
« Reply #2 on: June 15, 2005, 10:21:20 am »
Hey thanks for the input.
I am still not comfortable designing my cab down to this detail without the monitor in front of me. Think I will just order the monitor and work out the finer bits once I can see it all for myself.
Ghoward
  • Mame rocks!!
« Reply #3 on: June 15, 2005, 02:36:10 pm »
That is the best way to go. I don't build a cab without the major parts its way to easy to make a mistake.
Gary
T Man
  • Last login:June 16, 2005, 08:08:33 pm
« Reply #4 on: June 16, 2005, 02:28:54 pm »
I just finished my cab up using the WG9200. I made a flat shelf that the monitor rests on, I recommend doing this because it is very heavy and having it sit on the shelf makes it easy to put your brackets in the positions you want. Then I made two 4 inch strips using 3/4 plywood to match up to the holes on the front of the monitor, these strips will be screwed into each side of the cab, to keep the front from moving. For the back I used 2 x 6's and bolted the top and the back of the brackets on the monitor. At this point I could remove the shelf but I just made cutouts for cables and cords in the shelf, the extra support never hurts, so now when I put the unit on a dolly the monitor is not budging.
You could use plywood to cut out the face, but I used some balsa type strips from home depot because they bent to go along with the curve of the screen, these were 4 in wide and I had to trim quite a bit off but I was able to get the rounded corners and put them on the unusable portion of the picture tube, so this frames the tube perfectly, add a sheet of lexan and your done.
Sorry to ramble, but the shelf is the key I wanted to point out, by setting it on the shelf, it sets up a pretty nice angle that makes it look like the monitor is tilted...no matter what, your going to be impressed with the 9200, games look great!
Bones
  • [Moderator]
« Reply #5 on: June 21, 2005, 09:30:48 am »
Thanks T Man. It's also good to hear some more positive stuff about the 9200 after reading of some bad experiences.
