Author Topic: Wiring computer output through car amp to cab speakers?  (Read 1242 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« on: June 09, 2005, 03:51:41 pm »
Picked up a cheap car amp.  My cab came with four built-in speakers.  Have some speaker wire.
If I don't care about stereo sound (amp is only mono anyway), how do I hook 'em up?  Just get some old headphones, etc. for the 1/8" jack then cut off  the earphones on the other end and splice the speaker wires to them?
(Then run wire to amp, then to speakers)
SS427
  • Last login:October 07, 2017, 12:04:24 am
  • Slow Poke, He pack a gun!
Re: Wiring computer output through car amp to cab speakers?
« Reply #1 on: June 09, 2005, 04:35:59 pm »
Suggest using a stand alone computer power supply (this is how mine is setup) instead of hooking up to your computer power supply...or power thru other means.
Here's a link to Zakk's site over at Massive giving amp install instructions.
http://www.mameworld.net/massive/How-to/Amp_Install/amp_install.html
ss
ShinAce
  • Last login:January 16, 2007, 07:38:14 pm
  • Building the unbuildable since 2001
« Reply #2 on: June 09, 2005, 06:40:47 pm »
For the amount of volume you'll need, I recommend wiring all four speakers in SERIES.
An ounce of image is worth a pound of performance.
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
« Reply #3 on: June 09, 2005, 07:52:15 pm »
Definitely. You don't want to kill your PC (even if temporarily) if you turn up the volume at a party or something.
-- Chris
Underway: Joey's Arcade
