Author Topic: Alt + Tab using an IPAC?  (Read 5359 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: June 09, 2005, 03:37:36 pm »
is there a way using shift you can program an ipac circuit board to allow you to press control and tab to switch between apps running on an arcade cab?
« Last Edit: June 09, 2005, 05:52:33 pm by eggedd2k »
AlanS17
    • AlanS17
Re: Alt + Tab using an IPAC?
« Reply #1 on: June 09, 2005, 03:43:03 pm »
You can program seperate "alt" and "tab" and wire them through the same button.
What are you trying to switch between, though. Those are both valid keys in MAME. So it's doable from the IPAC, but I don't know how much MAME would like it.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: June 09, 2005, 03:44:29 pm »
is there a way using shift you can program an ipac pcp to allow you to press control and tab to switch between apps running on an arcade cab?
Don't know what a pcp is, but you can assign a macro to a button with the latest Win-IPAC software.  I think you right-click on the button and there's an option for it.
vibez
  • Last login:February 09, 2011, 08:33:20 am
« Reply #3 on: June 09, 2005, 03:55:40 pm »
Macro function! Thanks for the heads up. This opens up so many possibilties for me
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: June 09, 2005, 03:57:40 pm »
I think you are limited to a maximum of 4 macros of up to 4 keys each per codeset, but it seems like a really useful feature.
eggedd2k
« Reply #5 on: June 09, 2005, 05:54:14 pm »
alt would already be a one of the player buttons so that's not a problem.  i'll be switching between mame and wincab.
i guess i'll have to have an additional button for TAB
AlanS17
    • AlanS17
« Reply #6 on: June 09, 2005, 05:56:40 pm »
If you're just mapping the buttons to the seperate keys, why do you need macros?
eggedd2k
« Reply #7 on: June 10, 2005, 03:33:48 am »
i was just wondering if there's another way of mapping a TAB button. obviously ALT is part of player one's control set.
it's for switching between programs on the cab
Tiger-Heli
    • Tiger-Heli
« Reply #8 on: June 10, 2005, 10:44:58 am »
Assume this is a general question (not specific to this thread)???
You might want a dedicated button on the cab for Alt-Tab, rather than having to remember to press P1B2 and (whatever you assigned to Tab).
Also many programs use ALT-F4 to exit (or ALT-X), or.  It's more convenient to load a custom codeset for these games with ALT-F4 mapped to your Escape key than to have to remember to press P1B2 and (whatever you assigned to F4) for these games only.
