Author Topic: mamewah  (Read 1117 times)
amerish
  • Last login:June 20, 2015, 11:01:33 am
  • Why build 1 when you can build 2 at twice the cost
    • You Saw It On TV
mamewah
« on: June 09, 2005, 01:09:06 pm »
Can I just copy mamewah from one computer drive to another or do I have to install then overlay the folders?
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re: mamewah
« Reply #1 on: June 09, 2005, 01:15:25 pm »
  Nope, there shouldn't be any problem as long as you install the system files on the new computer, then you can just copy the entire MAMEWAH folder over.
  To make the migration easier you want to try and keep exactly the same paths.  For example, if MAMEWAH is installed in C:\MAMEWAH, make sure it's C:\MAMEWAH on the other computer.   The same holds true for any emulators.
-sab
