Author Topic: WG K7000.. No Glow!!  (Read 1032 times)
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« on: June 09, 2005, 11:35:02 am »
Last night I picked up a TMNT cab and before it was moved the monitor powered up and displayed the game, albeit that it needed a cap kit. After we moved it and powered up the game the monitor sounded like it was powering up, but I could see no glow in the CRT heater. I checked all of the cables and everything is connected. If there is no glow in the tube what should be my first thing I should check?? The neck looked fine. I didn't see any cracks in it and it was crackling when I turned on the power and the tube had static on it. I just have no glow in the tube.
Sould I check for bad solder joints first?? What could jar loose that would cause this during the move?? I even made sure the neckboard was pushed in all the way.
Karetaker
  • Last login:July 28, 2022, 08:19:40 pm
Re: WG K7000.. No Glow!!
« Reply #1 on: June 09, 2005, 02:00:33 pm »
It could just be a loose ground on the chassis frame. Looking at the back of the monitor there should be a black wire connected to the frame on the left side. Make sure it's hooked up and making good connection.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: June 09, 2005, 06:09:50 pm »
It's also possible that one or more capacitors have finally died causing a 'no power up' symptom. So I would advise to get that capkit in there right now, check for bad solder joints, and examine the flyback for signs of cracking.
