Author Topic: have some wires question..  (Read 1355 times)
alundra
  • Last login:February 02, 2009, 09:30:05 pm
« on: June 07, 2005, 11:28:39 pm »
my cabinet just arrived..when i check the inside..i saw some green wires that connect from the monitor metal frame that lead to no where, am assume this is the ground wires or something..am i suppose to ground this some where? thanks
« Last Edit: June 08, 2005, 12:08:12 am by alundra »
Apollo
    • Eight Bells
Re: have some wires question..
« Reply #1 on: June 08, 2005, 12:10:55 am »
Yes ground is usually green and thicker than other wires, you can attach the ground to a metal control panel or the monitor mount.
alundra
« Reply #2 on: June 08, 2005, 12:14:01 am »
can i attach those wire to a screw near by..cause there is one green wire that also attach to screw..basically i can attach these wire anywhere that has metal right?
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« Reply #3 on: June 08, 2005, 01:09:59 am »
I'm speculating a bit here, but if you are wiring up a 4-slot neo geo there are some additional considerations.  It has something to do with the -5v and the sound.  You should look into it.  There is also some good info here.
http://www.hardmvs.com/index.htm
alundra
« Reply #4 on: June 08, 2005, 01:33:33 am »
no this is for a jamma cab..i have to figure out how to hook all those wires up..theyre all apart..
« Last Edit: June 08, 2005, 01:36:38 am by alundra »
