Author Topic: MAMEWAH + CPViewer - screensaver prob.  (Read 2129 times)
tore-
  • Last login:June 11, 2014, 06:18:33 am
« on: June 04, 2005, 11:48:14 am »
Hello.
When using MAMEWAH and CPViewer together and using screensaver-type run_random_game_then_quit(?), I have some problems with the screensaver.
It tries to load the game, but insteed it launches CPViewer, if i press the assigned key for exit in CPviewer, the game loads.
Here are my confs:
Code: [Select]
mamewah.ini
### mamewah.ini (mamewah v1.61) ###
### (Global) Screen-Saver Options ###
delay                       30
slide_duration              3
### Audio Options ###
enable_sounds               1
sound_volume                100
music_path                  E:/Music
enable_music                0
music_volume                100
### Movie Options ###
intro_movie_file
exit_movie_file
keep_movie_preview_aspect   game_aspect
delay_before_movie_preview  2
music_movie_mix             mute_movies
movie_volume                100
### Misc Options ###
layout                      layout
ctrlr
wrap_list                   0
remember_current_game       1
keep_image_aspect           1
refresh_images              0
correct_orientations        horizontal
safe_mode                   0
show_cursor                 0
keyboard_led_states         -,-,-
winipac_file
mamewah_ipc_file
lcd_com_port                1
lcd_settings
exit_action                 choice
app_to_run_on_exit
### Settings used by MAMEWAH ###
current_emulator            mame
locked                      0
last_ipc
mame.ini:
### mame.ini (mamewah v1.61) ###
emulator_title                            M.A.M.E.
### List Generation Settings ###
rom_path                                  E:\Arcade\MAME\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file                           E:\Arcade\MAME\catver.ini
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
emulator_executable                       E:\Arcade\MAME\mame.exe
commandline_format                        [name] -skip_disclaimer -skip_gameinfo -high_priority -sl -effect scan75 -resolution 800x600 {autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      E:\Arcade\MAME\snap
artwork_2_image_path                      E:\Arcade\MAME\cpanel
artwork_3_image_path                      E:\Arcade\MAME\marquees
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                run_random_game_and_quit
movie_path
movie_fullscreen                          1
quit_delay                                180
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable                          E:\Arcade\CPViewer\cpviewer.exe
app_1_commandline_format                  [name] -clone [cloneof]
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps                          1
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
current_list                              11
Any workaround for this?
Edit: Also, if you play a game while the screensaver is active, it will quit after the given seconds in the ini file, tips?
« Last Edit: June 04, 2005, 01:13:43 pm by tore- »
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
Re: MAMEWAH + CPViewer - screensaver prob.
« Reply #1 on: June 04, 2005, 02:25:36 pm »
Just a guess, it may be b/c of the "auto launch apps" equaling 1 but Im not sure
tore-
« Reply #2 on: June 04, 2005, 08:41:07 pm »
Hm thats quite right, but then again it would be extremly handy if I could autolaunch CPV. when starting a game, but not when the screensaver is activated.
But I would tip that there is no workaround for that.
sc1103
« Reply #3 on: June 04, 2005, 11:36:18 pm »
Wait for screaming's post, he knows a lot more about MAMEWAH than I do... :P
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #4 on: June 06, 2005, 08:25:11 am »
Here are my confs:
snip
  This is probably a minor oversight on Minwah's part, but I haven't tested it on my cab to be sure.
  Either way, you should be able to work around it:
1) Make a batch file that launches CPViewer, then MAME, like
Code: [Select]
IF [%1]==[ss] goto SS
E:\Arcade\CPViewer\cpviewer.exe %1 -clone %2
E:\Arcade\MAME\mame.exe %1 -skip_disclaimer -skip_gameinfo -high_priority -sl -effect scan75 -resolution 800x600
goto DONE
:SS
E:\Arcade\MAME\mame.exe %2 -skip_disclaimer -skip_gameinfo -high_priority -sl -effect scan75 -resolution 800x600
:DONE
2) Set your commandline_format to
Code: [Select]
ss [name] {nodosbox}{nosafelaunch}
3) Set your alt_commandline_format_1 to
Code: [Select]
[name] [cloneof]{nodosbox}{nosafelaunch}
4) In your controller file in MAMEWAH, set the LAUNCH_GAME_WITH_OPTIONS1 key to the same thing as LAUNCH_GAME, and delete whatever's there for LAUNCH_GAME.
  Basically, you're working off the premise that MAMEWAH will launch the game using the default commandline_format, while you can control how you launch the game with the other alt_commandline_format_1/2, and your batch file will differentiate the two.
  Again, I haven't tried it (just got back from vaca) so YMMV.  If you have any problems, I'll check it out when I get home from work tonight.
  Hmm. Again, this is probably a minor oversight on Minwah's part but I haven't checked it out on my cab to be sure. I can't think of a good simple workaround for this, aside from changeing your saver_type to run_random_game_using_wrapper and using Howard Casto's emusaver wrapper for your screensaver.
  I'd like to use this option as my screensaver, so I'm curious if this is a "bug".  I'll check it out when I get home tonight.
-sab
tore-
« Reply #5 on: June 07, 2005, 06:09:39 pm »
Did what you said, i didnt make it to work:
08.06.2005 00:06:49 MAMEWAH launched
08.06.2005 00:06:49 Cursor scheme: 3D-White, Arrow: C:\WINDOWS\Cursors\3dwarro.cur, Wait: C:\WINDOWS\Cursors\hourgla3.ani, AppStarting: C:\WINDOWS\Cursors\appstar3.ani
08.06.2005 00:06:49 Desktop colour: 10841658
08.06.2005 00:06:49 Wallpaper filename:
08.06.2005 00:06:49 Display mode: 1280x1024 @ 60Hz, 32 bit colour
08.06.2005 00:06:49 Decimal symbol: ','
08.06.2005 00:06:49 Games list read: mame-11.lst
08.06.2005 00:06:54 Layout selected: E:\Arcade\MAME\layouts\layout\mame.lay
08.06.2005 00:06:59 Ctrlr file selected: E:\Arcade\MAME\ctrlr\default.ini
08.06.2005 00:07:29 Bad image file: E:\Arcade\MAME\layouts\mamewah-art.png
08.06.2005 00:07:30 Commandline run: E:\Arcade\MAME\mame.exe Start ASURABLD  {flags=9}
08.06.2005 00:07:41 Bad image file: E:\Arcade\MAME\layouts\mamewah-art.png
08.06.2005 00:07:55 MAMEWAH quit
« Reply #6 on: June 07, 2005, 06:19:23 pm »
The 'Start' here is causing the problem I think...not sure where that is coming from tho.
I think screaming is probably right (ie an oversight on my part)...could you please let me know for sure if you have chance to test it screaming?
