Author Topic: Eject/Fire button for Control Panel  (Read 2463 times)
Solarix
  • Last login:July 05, 2005, 10:46:36 pm
« on: June 03, 2005, 10:21:54 pm »
I am in the process of making my first MAME machine. and I wanted to know, if anyone knew where i could purchase a fire/eject button with that little plastic cover over it. Here is a picture of one from the controller for Steel Battalion.
Click to Enlarge
Thanks in advance for any assitance
Chris
    • Chris's MAME Cabinet
Re: Eject/Fire button for Control Panel
« Reply #1 on: June 03, 2005, 10:28:50 pm »
That cover is likely part of the case, not part of the switch.  This is probably something you'll have to construct...
--Chris
NeeBick
  • Last login:April 15, 2011, 01:14:02 am
« Reply #2 on: June 04, 2005, 12:00:00 am »
Closest I have seen are these:
http://www.frozencpu.com/ele-95.html
but they are not momentary.
quarterback
« Reply #3 on: June 04, 2005, 12:17:05 am »
But it looks like you could remove the toggle switch (by unscrewing it) and replace it with something else like the momentary push switches from Radio Shack
EDIT:
« Last Edit: June 04, 2005, 12:19:57 am by quarterback »
-- Chad Tower
AmericanDemon
  • Last login:February 27, 2026, 01:01:31 am
  • Still an AmericanDemon
« Reply #4 on: June 04, 2005, 12:57:50 am »
yeah but that 4.99 item exudes cheap switch.
rdagger
« Reply #5 on: June 04, 2005, 03:45:49 am »
Solarix
« Reply #6 on: June 04, 2005, 10:38:28 am »
Thanks for the help guys, I will probably pic up that radio shack one just since i will have to replace the switch anyway with a momentary one. All this switch is for is for easy access to turn the PC on and off but i didnt want to inadvertently hit it.
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #7 on: June 04, 2005, 11:05:44 am »
Something like this might be what you're looking for as far as a switch, but as far as the acrylic housing goes, you might have to make that yourself. It really shouldnt be that hard. All you'd need is a small piece of lexan, a dremel, some silicone or clear epoxy, and a piano hinge.
I'll keep my eye out for anything that looks more liek what you need.
Signature tags are dumb.
Solarix
« Reply #8 on: June 04, 2005, 07:42:04 pm »
Well i decided to go with the Carbon Fiber looking one that was linked to on eBay ( I found it at AutoZone) I just got done cutting the board down into managable pieces today so if I have any other questions I will be sure to let you know.
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
« Reply #9 on: June 05, 2005, 06:48:08 pm »
I'm interested to know what you plan to do with this Solarix.
Flinkly
« Reply #10 on: June 05, 2005, 09:43:45 pm »
uh, he said in the pror post that he plans to make it a pc on/off switch.  he wants the cool cover to help him to not turn off the comp and an in-oportune time.
IntruderAlert
    • Intruder Alert
« Reply #11 on: June 05, 2005, 10:52:09 pm »
uh, thanks for pointing that out flinkly
