Author Topic: Grey N64 Controller + Boom Adaptor :(  (Read 2385 times)
Dagg
  • Last login:June 05, 2017, 04:23:59 pm
« on: June 01, 2005, 08:10:09 am »
Ok so a week or so ago I was trying to figure on the best way to control N64 on my cab,  like many others I went the route of buying an adaptor for the orignal controllers I owned.
My choices seemed to be the adaptoid or the lik-sang boom adaptor.  I decided on the lik-sang boom adaptor because it also handled PS1 and PS2 controllers.
So it arrives yesterday and I spend all night tinkering with it only to find out it doesnt work with some color N64 controllers.  Both of mine are grey and I can install it and calibrate them but when I select it under controller plugin I cannot remap the keys to the joystick inputs.
Has anyone had any luck with this thing, also if you did what color N64 controller are you using.
I either need to get controllers that work with this POS or buy an adaptoid (which I am thinking I should have done in the first place)
Teknique
  • Last login:October 02, 2015, 10:35:46 am
  • I'm a Gauntlet wizard in real life
Re: Grey N64 Controller + Boom Adaptor :(
« Reply #1 on: June 01, 2005, 10:00:41 am »
Colors dont matter, they need to be official (as in ...came with the system or marketed by nintendo) controllers - not some aftermarket cheapos.
Your screen name has been added to my frag list.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #2 on: June 01, 2005, 10:19:08 am »
Yeah, I had a Mad Catz controller that refused to work with that adapter, but my real (by Nintendo) N64 controllers worked fine, even the grey one.
Dagg
« Reply #3 on: June 01, 2005, 10:41:55 am »
They are the official Nintendo controllers.
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
« Reply #4 on: June 01, 2005, 10:51:43 am »
Wasn't grey the original color controller?
Seems kind of messed up, that those wouldn't work with any adapter.
Seems even more weird that the adapter is a racist in the first place though.
Dagg
« Reply #5 on: June 02, 2005, 02:12:57 pm »
Update:
Got this working but it was different for both of my grey original controllers (I had no idea any other color than grey existed until 2 days ago).
The first controller I used the "Restore Defaults" when in the Control Panel-->Gamepads, this made the controller more stable and I was able to map the keys in PJ64, I think what was happening was that the calibration was off and every time I tried to map a key it was seeing something on the gamepad as being pressed (the analog stick) and always filling that in.
I tried that for the second one but that didnt work, so I lowered the dead zone slider and was able to calibrate that on myself and finally get PJ64 to except the inputs.
