Author Topic: More input please... Dynamo Cab - Largest Monitor?  (Read 2382 times)
Kev-in DFW
  • Last login:September 10, 2008, 12:36:09 pm
  • Duke it out amongst yourselves...
« on: June 01, 2005, 04:37:25 am »
I don't know if any of you guys have any experience with converting an old Dynamo cab, but what is the largest monitor I can put in it (monitor or TV)?
« Last Edit: June 05, 2005, 11:40:51 pm by Kev-in DFW »
The biggest tragedy in life is not death, but what dies inside of us while we are still alive...
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
Re: Dynamo Cab - Largest Monitor?
« Reply #1 on: June 01, 2005, 07:02:37 am »
A 27" might fit, but 25" will definatly fit in that cabinet.
www.wolfelectronics.ca
Cap Kits for Canadians!
Ken Layton
  • Guru
  • Technician
« Reply #2 on: June 01, 2005, 09:36:47 am »
Dynamo cabinets were originally designed for 25" monitors maximum size.
AlanS17
    • AlanS17
« Reply #3 on: June 01, 2005, 02:09:24 pm »
You won't fit anything larger than a 25" in those things. That 23 3/4 is something of a standard inner width. Even just the tube on any larger monitor would be too wide to fit. In other words, a 27" will never fit.
A 25" with mounts should fit no problem, though.
Do you have a particular monitor in mind? You'll be able to fit a bigger monitor in there if you go with an arcade monitor. A TV has all that extra plastic that just gets in the way. Plus it has speakers and stuff you'll never use. Lots of people take the tv route because it's admittedly easier, but I think most of those people are usually building their own so they have appropriate shelves and stuff.
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
« Reply #4 on: June 01, 2005, 06:27:52 pm »
I mounted a 25'' inch monitor in my 19inch Dynamo (The one you have). I took out the inside wooden brackets and replaced with this 2 pieces of 2x4, which are used for the monitor mount. One for the top, one for the bottom  ;).
Kev-in DFW
« Reply #5 on: June 02, 2005, 03:45:23 am »
Thanks for all of the input and help.
Kev-in DFW
Re: More input please... Dynamo Cab - Largest Monitor?
« Reply #6 on: June 05, 2005, 11:41:39 pm »
bump... for more help after last long post!....  :)
AlanS17
    • AlanS17
« Reply #7 on: June 06, 2005, 09:59:26 am »
I've got 2 25" monitors, but unfortunately neither one is working. I can't imagine why you would want one, but you're welcome to buy one for crazy cheap.
Kev-in DFW
« Reply #8 on: June 07, 2005, 06:09:26 am »
Alan,
I thought you probably had several working 25" monitors laying around.  I know you have quite a few cabs.  I actually need a WORKING monitor though!
Thanks anyway!
Kev~
AlanS17
    • AlanS17
« Reply #9 on: June 07, 2005, 03:01:04 pm »
Nope, sorry! Can't help you there. I've got plenty of working 19" monitors, but my 25" monitors are busted right now. Most of my cabs are classics and, therefore, use 19" monitors.
