Author Topic: Book templates & routing  (Read 5069 times)
RTSDaddy2
  • Last login:April 03, 2014, 08:28:03 pm
  • Bees! Oh bother!
« on: May 29, 2005, 07:23:01 pm »
Here he comes again.
« Last Edit: May 29, 2005, 07:26:31 pm by RTSDaddy2 »
shodokan123
  • Last login:October 14, 2007, 01:57:20 am
  • Fighting Game Addict
Re: Book templates & routing
« Reply #1 on: May 29, 2005, 07:40:29 pm »
you use a 1/5 drill bit... dont use a router to make the hole.
if i remember correctly.
RTSDaddy2
  • Bees! Oh bother!
« Reply #2 on: May 30, 2005, 07:30:49 am »
God help me, it's a wonder how I ever got my cabinet built.
I decided to look back through the book to see what I could find about bits needed....and discovered that what I thought (again) was wrong....possibly.
I'm planning to use the Ultimarc T-stick that is switchable from 4-8 way from the top of the panel.
« Last Edit: May 30, 2005, 07:51:02 am by RTSDaddy2 »
RTSDaddy2
  • Bees! Oh bother!
« Reply #3 on: June 11, 2005, 06:19:39 am »
For what it's worth - the router bits DID actually come in handy!
Using the T-stick plus in 3/4" plywood.  Got my 1 1/8" hole drilled, took the shaft out, and reconnected everything to discover the shaft was too short!
I wound up needing my bit to recess the stick into the wood and make the stick taller anyway - so the bits weren't  a waste of money after all!
RTSDaddy2
