Author Topic: need help hacking an IDE cable  (Read 1467 times)
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« on: May 29, 2005, 06:11:12 pm »
I thought I knew the way the pins worked but now I'm not sure.  If the red wire is pin 1 and the one touching it is wire 2 and so on, then is this the right pin layout?
2  4  6  8  10...
1  3  5  7    9...
To be more specific
If I have the red pin on the left.  Would the "joymode button be the 14th wire?  And would button 1 be wire 35 (or 5 from the right)?
monkeybomb
Re: need help hacking an IDE cable
« Reply #1 on: May 29, 2005, 06:16:56 pm »
oh yeah
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #2 on: May 29, 2005, 07:09:53 pm »
If you are using the GP-Wiz 49 with the IDE header then I believe you are right on the money.
monkeybomb
« Reply #3 on: May 29, 2005, 07:15:42 pm »
Dude I saw you were loged on and I knew I was close to an answer.
Thanks  a lot
1.....2......3......4.....oh wait, I'll do this by myself
markrvp
  • NFL Expert
« Reply #4 on: May 29, 2005, 07:26:23 pm »
