Author Topic: A little wiring help  (Read 2405 times)
Urata
« on: May 06, 2002, 01:45:08 am »
I'm really unexperienced and I am trying to build a Playstation to PC connector.
I understand everything except for exactly what to do with the multi-meter. On top of the fact that I'm new to this, I'm reading a seemingly badly translated (from spanish to english) web page.
Here is the article I'm reading.
http://www.emulatronia.com/reportajes/directpad/psxeng/index.htm
aramis
  • Last login:November 26, 2002, 09:24:04 pm
  • mame cab ALMOST done!
Re: A little wiring help
« Reply #1 on: May 06, 2002, 08:47:25 am »
First, let me say that I have never built a PSX to PC converter, so I can't say whether or not those instructions are actually correct.
As far as the multi-meter goes, I think he meant you should use it to test the power supply if you are using the force feedback ability of the controller. In other words, make sure your power supply is really a 9Volt DC supply (test it w/ the multimeter) before connecting it to the psx pad.
Again, whether a 9volt supply is really what you should use, I don't know...but that's what the instructions on that page suggest.
Hope this helped...
