Author Topic: Any of you dev has a listxml to access 2000 utility right now?  (Read 1677 times)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
I could write one but I want to see if someone else has and will let me use it.
SirPoonga
  • Puck'em Up
Re: Any of you dev has a listxml to access 2000 utility right now?
« Reply #1 on: May 27, 2005, 02:55:53 pm »
bah, I think I will just write my own vb app with domdocument to grab the info I need from listxml.  If I had office 2003 this would be alot esier to do....
controls.dat will be updated as soon as I finish writing this :)
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #2 on: May 27, 2005, 05:38:34 pm »
Uhm, ListGen and ListGen.NET can export any data you want in anything-you-want-including-tabs-or-commas-delimited format, which should import nicely into any database.
-Steve
SirPoonga
  • Puck'em Up
« Reply #3 on: May 29, 2005, 09:40:34 pm »
Hmmmm.  now I have to learn to use it.  Says I needc to select a platform and none are listed :(  I need to find docs :)
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #4 on: May 29, 2005, 09:59:21 pm »
Yes give listgen a try - should be fine if its a one off transfer you want....
If you end up writing a VB app, I would avoid the Domdocument approach if you are using the mame xml info (ie very big). Its extremely slow. Use a Sax parser to pull the info you want into an array or something (assuming you know what you want from the XML file first of course).
SirPoonga
  • Puck'em Up
« Reply #5 on: May 29, 2005, 10:27:42 pm »
I need these fields tab delimited
romname
description
category
romof
cloneof
tilt
cocktail
where tilt and cocktail are 0 for no and 1 for yes.  All this info is in listxml.
SirPoonga
  • Puck'em Up
« Reply #6 on: May 31, 2005, 02:11:25 pm »
I decided to write my own, unless the makers of listgen want to talk to me about what I am trying to do.  DOM isn't that bad.  Expecially since all I need is selectSingleNode with the right XPath.  I made a quick parser over lunch that grabs the needed info from listxml.  Take less than a minute to run.
I don't think I use category anymore.  I think it is in the database from when I didn't want mahjong games in it.  I will have to verify.  Otherwise the rest of those fields come directly from listxml.
screaming
  • Registered lUser
« Reply #7 on: May 31, 2005, 02:21:23 pm »
romname
description
category
romof
cloneof
tilt
cocktail
  ListGen and ListGen.NET (the released one anyway) do not parse the dipswitch settings, so they don't know anything about cocktail mode or tilt unless it's defined elsewhere (gamelist, catver, etc).
  Getting an output in tab delimited of any of those fields is elementary to both applications though.
-Steve
SirPoonga
  • Puck'em Up
« Reply #8 on: May 31, 2005, 02:34:42 pm »
Well then, I will just have to make my own thing.  I need the tilt attribute form the input element and the cocktail dipvalue.
