Author Topic: Why Galaga PCBs so expensive?  (Read 4997 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: May 27, 2005, 10:47:28 am »
I have noticed that Galaga pcbs seem to command premium prices. But why?
I assume this is because they are still good money makers in commercial situation?
SirPeale
  • Green Mountain Man
Re: Why Galaga PCBs so expensive?
« Reply #1 on: May 27, 2005, 10:51:31 am »
You are correct.  Despite being one of the most manufactured boards, they command high prices due to their demand.  Since the market supports it, people will pay it.
MonitorGuru
« Reply #2 on: May 27, 2005, 12:05:40 pm »
Same with Pac-Man and Ms.Pac.  Why do you think Namco released the Ms.Pac/Galaga reunion machine?
Pac prices have fallen over the last year to 2 years. Ms.Pac has fallen a bit less (same board, different chips+daughter board).  Pacs used to guarentee $200-$225 and Ms.Pacs $225-$250.
Now Pac-s are about $125 to $150 tops depending on condition, while Ms.Pacs are still about $175 to $200.
I need a Galaga board set.. I have tons of extra Pac's.. I wish I could trade a working Pac for a working Galaga, but doubt that will happen :(
« Reply #3 on: May 27, 2005, 12:22:36 pm »
Seeing as how either could be done in a single chip now, how prevalent are boots?
rchadd
  • Made in Cornwall
« Reply #4 on: May 27, 2005, 01:00:39 pm »
if only the arcadeshop 9 in 1 multi jamma pcb ran namco games...
or can they? ;)
« Last Edit: May 27, 2005, 02:38:34 pm by rchadd »
MonitorGuru
« Reply #5 on: May 27, 2005, 02:42:53 pm »
Speak and ye shall receive... Have been looking for a killer price on an authentic midway galaga pcb and I found one today momemts after I posted that last message!  Finally my Galaga cabinet i found on the side of the road (with great side art) can come alive!
I need to get the wire harness however... otherwise I have everything else i need I think.  Anyone have a cheap wire harness available?
SirPeale
« Reply #6 on: May 27, 2005, 05:05:33 pm »
I've got something cheaper, although it's still a Mame solution...
Get yourself a Delhi III motherboard.  They came in eMachines.  On eBay all the time.
There are DOS drivers for the sound, and there are onboard ATI graphics with non-shared memory.
Get a 16M flash card, with an IDE flash reader.  Set up DOS on it, with the sound drivers, and have it boot right to Mame and Galaga.
This board runs Galaga @ full FPS with a 450 MHz processor.  And with .96u3 it's darned close to the real thing.  In fact, with the newest version I'm not sure what the difference is between Mame and a real board.
AlanS17
    • AlanS17
« Reply #7 on: May 27, 2005, 05:51:12 pm »
MonitorGuru
« Reply #8 on: May 27, 2005, 06:15:05 pm »
Thanks guys, but I require the original system and original (or at least redone to original) wiring harness.. I dont want to convert it to Jamma or mame it...
I got into mame, but have much more fun restoring classics... I still havn't built a mame and probably never will.. I just use it to test games out before I buy them now :)
« Reply #9 on: May 28, 2005, 08:49:32 am »
You know, I have one of these sitting 8 feet from me, 533mhz I believe.
SirPeale
« Reply #10 on: May 28, 2005, 02:43:16 pm »
Yeah?  Check it and make sure the specs I mentioned above are inside.
