Author Topic: Marquee light and speaker shield question...  (Read 1229 times)
dema
  • Last login:September 02, 2014, 03:05:34 am
« on: May 26, 2005, 04:46:23 pm »
Do marquee lights get very hot? I don't have a lot of space because my speakers are a little large, and I'm going to put the speakers behind a piece of 1/8" thick marker board, which will make the space even more confined. The one side of the marker board is a very glossy white, so it should help make the area really shine to compensate for the lack of space, but I wanted to make sure it didn't get too hot to cause any fire concerns.
I'm sure this is a stupid question but I haven't picked up a marquee light or installed the separator yet, so I thought I'd ask.
« Last Edit: May 26, 2005, 04:52:30 pm by dema »
slayj
  • Last login:January 10, 2006, 02:49:56 pm
  • Anybody seen my joy...???!
Re: Marquee light and speaker shield question...
« Reply #1 on: May 26, 2005, 04:48:32 pm »
Depends on the light.  Flourescent should be fine.......
Did you know if a frog had wings it wouldnt bump its butt!!!
Q*Bert_OP
  • Oh yes, we did!
« Reply #2 on: May 26, 2005, 05:14:11 pm »
Just put a mini computer fan up there.
Never use regular light bubs.
Pac man has regular light bulbs, and it gets very hot up there!1
HoopstarsGarage
  • Scratch Building Demi-God!
  • Last login:April 19, 2016, 09:24:11 pm
  • Scratch Building Demi-God..
    • Hoopstars Garage
« Reply #3 on: May 26, 2005, 09:45:54 pm »
I am in the process of building a Centipede Replica (Check it out here) and the area between the marquee and the speaker panel is quite tight  - tight enough that I had to do some engineering to get everything to fit.  I have had the 18 watt fluro in there running for about 12 hours in tests and the marquee glass would only be considered slightly warm to touch.  I don't think it is an issue to be honest..
Hoopstar
dema
« Reply #4 on: May 26, 2005, 11:49:34 pm »
Cool. Thanks for the information guys. I'm glad to hear that the tight real estate will work out without any heating concerns.
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
« Reply #5 on: May 27, 2005, 12:38:52 am »
You could always go to a PC mods website and buy a cold-cathode flourescant that plugs directly in your PC's power supply. They run cool, last a long time, generally are compact because they're meant to fit inside PC cases, and have the ease of a molex connector.
