Author Topic: Changed Folder for Music in MamewahConfig.. still plays from old folder?  (Read 1268 times)
daveg2000
  • Last login:January 02, 2009, 08:55:51 pm
  • PSP? Yeah right. GP2X Baby! This thing is awesome
    • www.davegrams.com
I pointed Mamewah (using the Config program) to a different folder
filled with MP3 files, and it continues to play from the original folder
that I created, rather than the new one.
(I even checked the mamewah.ini file and it has the NEW folder
path... so I dont get where it is still seeing the folder with the old music....?)
weird.
...so I will ask you... "Deal, or No Deal?"
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
  There are a couple places you can define your music path.
1) Global settings, music_path in mamewah.ini (or the Global Settings tab in MC)
2) Emulator settings, music_path in emuname.ini (or the Emulator Settings tab in MC)
  MAMEWAH will use the GLobal Settings option if the Emulator Settings option is blank.  Otherwise it uses the path in the Emulator Settings tab. You can set it in both of you like, or ONLY in the Global Settings if you want the music folder to apply to all your emulators.
-sab
