Author Topic: Question for an electronics repair guy..  (Read 3436 times)
Knievel
    • Knievel Kustoms
« on: May 24, 2005, 02:41:49 pm »
I've got a glass touchscreen with a ribbon cable coming off it and the cable has come loose from the wiring on the glass. If I squeeze the cable against the glass it works fine.
Is there a way to reconnect the ends of the ribbon cable to the wiring..I'm thinking a conductive adhesive or something? I don't think I can solder to the trace on the glass.
Re: Question for an electronics repair guy..
« Reply #1 on: May 24, 2005, 02:47:07 pm »
Pics?  You're going to have to elaborate on this "wiring on the glass".
Knievel
    • Knievel Kustoms
« Reply #2 on: May 24, 2005, 05:08:08 pm »
Tough to get a good picture of it, this is from the backside...
« Reply #3 on: May 24, 2005, 07:04:00 pm »
Your best bet is to wire jumpers to the ribbon cable.
Knievel
    • Knievel Kustoms
« Reply #4 on: May 24, 2005, 07:27:36 pm »
Yea..my only concern is getting solder to stick to whatever that wiring on the glass is made out of. Was hoping there would be a product to re-secure it.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:Yesterday at 08:58:13 am
« Reply #5 on: May 24, 2005, 08:20:40 pm »
I'd be tempted to hold it down so the ends properly line up, and fasten it with some sort of adhesive, such as hot glue (though I would make sure it wouldn't melt first).
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Ken Layton
  • Guru
  • Technician
« Reply #6 on: May 25, 2005, 12:00:05 am »
If it's a MICROTOUCH brand touchscreen, I'd contact the manufacturer's tech support dept and/or checkout their FAQ page for repair information. Microtouch uses real glass in their touchscreens.
If you have an ELO brand then I feel very sorry for you. ELO is the cheapest POS plastic touchscreen I've seen. Pure crap.
« Reply #7 on: May 25, 2005, 08:55:53 am »
That's a better solution IF he can hold it in place securely enough to test connectivity without gluing it first.
Knievel
    • Knievel Kustoms
« Reply #8 on: May 25, 2005, 11:31:31 am »
Thanks guys. Ya it's an ELO, glass with a plastic front skin.
The glue idea is good but unfortunately it needs quite a bit of pressure to make contact. I'm going to take a stab at soldering it before it hits the trashcan. I'll let you know how it goes...
« Reply #9 on: May 25, 2005, 11:35:40 am »
If you were to clamp something larger onto it tightly, then hot glue that object down, it may provide enough pressure to maintain the contacts.  Or you could just rig up a tiny clamp to it and leave it there... maybe a plumbing type clamp somehow, or just rig something that tightens with screws to hold it down.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #10 on: May 25, 2005, 04:34:04 pm »
I'd avoid glue. Too easy for the glue to seep inbetween and actually BLOCK contact.
NO MORE!!
tommy
« Reply #11 on: May 25, 2005, 07:32:22 pm »
If you're going to glue it i would suggest a UV glue, you need to make the glue hard with a black light but it holds much better then hot glue and its made to use on glass.
SirPeale
  • Green Mountain Man
« Reply #12 on: May 26, 2005, 08:01:44 am »
What about tape?  Align the wires where they should be (you may need a helper) and tape it down.
Now of course you couldn't use Scotch tape or the like, but something *much* stronger.
« Reply #13 on: May 26, 2005, 09:58:27 am »
Would tape provide enough downward pressure?
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
« Reply #14 on: May 27, 2005, 05:59:17 am »
Conductive paint, as used to repair car window heaters. Paint that between the 2 surfaces
« Reply #15 on: May 27, 2005, 09:07:12 am »
The odds of doing that and not shorting out two traces are really, really low.
