Author Topic: goodsnes help...  (Read 1882 times)
Notman
  • Last login:May 26, 2005, 07:27:33 am
goodsnes help...
« on: May 24, 2005, 12:56:22 pm »
does anyone have a program that can edit out a good list... i used goodmerge but a lot the games it left me with are the wrong versions (ie. in japanese, etc..).. a while back someone posted a program good parser, i tried using it but it wont work... basically i was looking for a program that will go through the list pick all the [!] or versions and merge them into one list
Teknique
  • Last login:October 02, 2015, 10:35:46 am
  • I'm a Gauntlet wizard in real life
Re: goodsnes help...
« Reply #1 on: May 25, 2005, 05:47:39 pm »
Your screen name has been added to my frag list.
Notman
« Reply #2 on: May 26, 2005, 07:27:33 am »
http://forum.arcadecontrols.com/index.php/topic,10306.0.html
im looking for a program that works exactly like this... when i try to run this program it gives me an error message and the program will not start up...is there some reason why this program doesnt work?
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
« Reply #3 on: May 26, 2005, 08:25:23 am »
Use GoodGUI and sort into folders automatically.
http://www.zophar.net/utilities/goodutil.html
Brad
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
« Reply #4 on: May 26, 2005, 08:50:11 am »
You know you can just do this with windows search right? Search for (u) or (!) or [o?] or whatever in your roms folder, select the results, cut and paste into a new folder.
Dagg
  • Last login:June 05, 2017, 04:23:59 pm
« Reply #5 on: May 26, 2005, 10:49:00 am »
 Yeah I spent a few hours trying to figure out the Good GUI and associated GoodNES, GoodSNES tools etc and finally scrapped it all and just used the XP search as listed above.
I searched for all files with in them and seperated them to a a folder called usaroms (make sure to change your ini file if you do this), I then deleted that selection from the old roms folder and then renamed it otherroms (or if space is an issue and you can just delete it)  Depends what your after and why you are doing it.
