Author Topic: Hantarex Polo Vertical Image Scroll not solved in lasts post :-(  (Read 3272 times)
pirateremain
  • Last login:May 26, 2005, 05:39:41 am
Hello my friends,
« Last Edit: May 24, 2005, 03:30:09 pm by pirateremain »
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: Hantarex Polo Vertical Image Scroll not solved in lasts post :-(
« Reply #1 on: May 24, 2005, 07:47:13 am »
Yeah, buy a video amp from ultimarc.
Your problem probally is that the video card only outputs .7v on the sync and the monitor expects 5v.
Or you might need to bulid a circuit to combine your sync.
So you need a video amp.
(Or at least a sync amp and combiner)
You can use the video amp only.
http://www.ultimarc.com/vidamp.html
or a jpac that has the amp built in (It also has sync protection to keep non 15k signals from reaching your monitor)
Later,
dabone
pirateremain
« Reply #2 on: May 24, 2005, 09:06:40 am »
Ohh thankkss your are my rescuer.  ;D
But I can damage the monitor with connect to AVga with my arcademonitor without jpad?
AVGA always out 15hz?? then J-pad isn't need   :o ?? or you advise me buy J-pad or video amp??  ???
I think connect buttons with hackpad but... It's better buy J-pad and all problems disapear??
Thanks for all my friends
See you soon,
PirateRemain
dabone
  • Time to work...
« Reply #3 on: May 24, 2005, 09:16:31 am »
Some monitors can handle the lower voltages of the avga card, some require a amp.
And no, you wont damage your monitor with the avga only.
Later,
dabone
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
« Reply #4 on: May 24, 2005, 09:56:34 am »
I thought you were supposed to use the Hantarex monitors with just the ArcadeVGA's 1v
also, aren't you supposed to just combine H sync and V sync for composite sync on the ArcadeVGA without building a circuit?
« Last Edit: May 24, 2005, 09:58:32 am by IntruderAlert »
pirateremain
« Reply #5 on: May 24, 2005, 10:39:57 am »
Yes I supposed this I connect Vsync and Hsync without any circuit.  :((uff my english ... more teoric classes.. excuse me) ;D
I only have:
1- R
2- G
3- B
4- Gronund
5- Vsync (no cable
« Last Edit: May 24, 2005, 11:55:59 am by pirateremain »
dabone
  • Time to work...
« Reply #6 on: May 24, 2005, 11:48:36 am »
Yes just connect the horzontial and vertical syncs together.
Later,
dabone
MonitorGuru
« Reply #7 on: May 24, 2005, 12:06:36 pm »
Run the combined H+V sync wire to both pins 5 and 6 on the monitor.
E.g.
13 + 14 on the VGA card, combine into one wire (as you already have)
then
connect the one wire to both pins 5 and 6 on the monitor.
If this doesn't work, then separate them and run one wire from pin 13 to pin 5 (mon) and 14 to pin 6 (mon) or vise-versa.
Also, you might want to connect the other ground connectors on the video card to pin 4 on the monitor.  There might be a difference in ground between RGB signal ground and Sync ground.  Connect them all together (pin 6,7,8, plus pin 5, 10 (also grounds) AND the shield ground from the connector itself (wire braides inside cable) into pin 4 of the monitor.   Do this only if the fix above doesn't help.
pirateremain
« Reply #8 on: May 24, 2005, 03:29:33 pm »
Yes, It's solved!!! LOL  ;D  ;D  ;D  ;D in effect 13 and 14 sync for the monitor H.S comp.. and another problem with the vga cable esquem.. this is a fromt image of the pings and I think this is a back image... the 13 ping Vsincy not connect correct   :angel: sorry
Thanks for all, your are the bests!!
Pirateremain
