Author Topic: 49-way joystick and the Xbox... is it possible?  (Read 1517 times)
ferrarimanf355
  • Last login:November 07, 2007, 09:09:54 pm
  • Trust me, I know what I'm doing!
    • TeamXbox
« on: May 23, 2005, 07:52:12 pm »
The subject says it all. I'm wondering if it's possible to, say, use the GPWIZ-49 to hook up a 49-way joystick up to an Xbox, and have the joystick switching done through a rotary encoder or a shift function. (shouldn't be a problem, since those functions are built in) Can it be done?
AmericanDemon
  • Last login:February 27, 2026, 01:01:31 am
  • Still an AmericanDemon
Re: 49-way joystick and the Xbox... is it possible?
« Reply #1 on: May 23, 2005, 08:05:40 pm »
Its a good question, but without the drivers the joystick wouldnt function.  I will allow others to fully answer, but I believe its not possible.
ferrarimanf355
    • TeamXbox
« Reply #2 on: May 23, 2005, 08:51:08 pm »
NoOne=NBA=
« Reply #3 on: May 23, 2005, 09:16:37 pm »
You don't need drivers on a PC because they are already built into the OS.
The GP-49 converts the data it receives from the 49-way into signals that are usable by Windows, using its own built-in drivers.
To the best of my knowledge, the X-box doesn't HAVE these drivers built-in, so would need its own custom ones.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: May 23, 2005, 11:07:01 pm »
Er, I'd say it a little differently (which gets a different view on possiblities).
49way + whiz49 (or AKI) = works, no special drivers needed in windows
49way + "49way 2 HallEffect" circuit = "works"*, no special drivers needed
49way + (unwritten) drivers in windows = works
49way all by itself = does not work on a PC (like a joystick)
49way all by itself = does not work in xbox/ps2
By the same logic, you either need a "special driver", or you need a special hardware before you hook up the 49way.  I think the latter is much more likely to happen; I bet the "49way 2 HallEffect" circuit will work as well as it did on the PC (maybe needs different resistors, though).  You still have to go through a hacked xbox/ps2 controller for it to work on the xbox/ps2 respectively, through.
*When I say "works", I mean the output was curved wrong for mame's 49way games.  Picture the curve the opposite of whiz49's "progressive" mode.
Edit: corrected the console named.
« Last Edit: May 24, 2005, 01:45:44 pm by u_rebelscum »
Robin
Knowledge is Power
