Author Topic: coin slot wiring diagram for ps & pc  (Read 11038 times)
danfaj
  • Last login:December 04, 2002, 05:36:44 pm
« on: December 04, 2002, 05:43:50 pm »
I have built my own arcade but I don't know how to connect the coin slot for my playstation and also for my pc. :-[
JustMichael
  • Mmmmm!! Cheesecake!!
Re:coin slot wiring diagram for ps & pc
« Reply #1 on: December 04, 2002, 06:08:40 pm »
A coin slot is connected the same way as a switch.  All the coin slot does is sort good coins from bad coins and then passes the good coins down a slot which trips a switch.
eightbit
  • My cab is never done...
« Reply #2 on: December 06, 2002, 03:18:20 pm »
Dan what are you using for an interface? Like JM said a coin slot is just another button. Do you currently have a button wired for credits?
BobA
  • What Me Worry?
« Reply #3 on: December 06, 2002, 04:00:17 pm »
There is no requirement to connect a coinslot to a playstation.  Your start button should play the game. Any arcade button wired to the start on the controller would work.
Bob
eightbit
« Reply #4 on: December 06, 2002, 05:38:50 pm »
I was wondering how you used coin slots with a ps. If you wanted you could wire the coin slot to the start button. It woud be neat the first  time you played then it would get annoying.
« Last Edit: December 06, 2002, 05:39:31 pm by eightbit »
alphasqorner
  • Last login:September 07, 2017, 10:55:43 am
  • The machine took my quarter!!!
    • AlphasQorner
« Reply #5 on: January 07, 2004, 12:35:36 pm »
<snipped by AlphasQorner for being a blind noob> ;)
« Last Edit: January 07, 2004, 12:47:32 pm by alphasqorner »
Visit www.alphasqorner.net: Home of AlphasQontroller (CP with "coin door-ed" stand)
