Author Topic: USB/PSX Gamepad interface question?  (Read 2294 times)
Warborg
  • Last login:April 09, 2026, 07:32:16 pm
  • Personal text? Nah...
« on: December 04, 2002, 02:13:32 pm »
Ok...  I was originally going to hack a Gravis Gamepad USB for my controls (which I actually did do in my test panel), but I've decided to change my design a bit...  I am now going to use a PSX/USB convertor from Radio Shack and a PSOne gamepad instead, due to the fact there are several more addressable buttons on the PSX pad then the Gravis pad, which will solve certain layout issues I was having.  Now I've heard that the USB system can only handle 6 simultaneous inputs, yet when I hooked up the gamepad to my system, I was able to hit ALL buttons on the pad plus one diagonal on the plus pad (10 inputs for buttons, and 2 for the diagonal), and it showed in the Game Devices panel (WinXP) that all inputs were registering.  Is the 6 input limit actually just for keyboards/keyboard encoders on USB?  I am seriously considering just using 2 of the PSX gamepads for both players, and want to make sure there are no problems between the two...  Has anyone had any experience with using 2 gamepads like this that they would care to share, or any input in general?
Warborg.
SNAAAKE
  • -Banned-
Re:USB/PSX Gamepad interface question?
« Reply #1 on: December 04, 2002, 02:53:31 pm »
everything works perfect..i used 4 converters before with no problem ever...just plug 1 converter first..install auto then do same with second...dont plug both together because you system would try to install both using same usb driver.radio shack converters work great..best !
