Author Topic: Problem With List Generation In Mamewah Help!  (Read 1941 times)
M.A.M.E Power
  • Last login:February 06, 2007, 04:25:59 pm
  • There Are So Many Games!
« on: May 22, 2005, 10:13:46 am »
Hi all
I have attempted to generate the main games list in mamewah for mame. However it stayed on the same number as before the generation started.
Have had a look in the documents but is does not specific how to sort this problem out. I have copied the log below it suggests that the list if full.
Any help is welcome
Lea
22/05/2005 15:04:47 MAMEWAH launched
22/05/2005 15:04:47 Cursor scheme: Windows default, Arrow: (None), Wait: (None), AppStarting: (None)
22/05/2005 15:04:47 Desktop colour: 6838104
22/05/2005 15:04:47 Wallpaper filename: C:\WINDOWS\VAIO GrandBlue Wallpaper TrueColor 1920x1200.bmp
22/05/2005 15:04:47 Display mode: 1280x768 @ 60Hz, 32 bit colour
22/05/2005 15:04:47 Decimal symbol: '.'
22/05/2005 15:04:55 Games list read: 01mame-1.lst
22/05/2005 15:04:59 Layout selected: D:\mamewah_v161\layouts\custom\01mame.lay
22/05/2005 15:05:02 Ctrlr file selected: D:\mamewah_v161\ctrlr\default.ini
22/05/2005 15:05:08 Games list read: 01mame-0.lst
22/05/2005 15:05:19 Commandline run: CMD.EXE /c d:\mame\mamepp.exe -listxml|xml2info > D:\MAMEWA~1\01mame.dat {flags=17}
22/05/2005 15:05:34 Commandline run: CMD.EXE /c d:\mame\mamepp.exe -listfull > d:\mame\listfull {flags=17}
22/05/2005 15:05:35 Games list read: 01mame-0.lst
22/05/2005 15:05:44 MAMEWAH quit
« Last Edit: May 25, 2005, 03:39:24 pm by M.A.M.E Power »
M.A.M.E Power
Re: Problem With List Generation In Mamewah Help!
« Reply #1 on: May 22, 2005, 11:18:39 am »
Hi Guys
I think that it may have something to do with the fact I have a main rom list (which you need) and I also have a filtered list which displays clones only if better than parent.
I think it may because these two lists together make up the amount of complete roms available to mame.
How can I rectify this problem?
M.A.M.E Power
« Reply #2 on: May 22, 2005, 06:51:03 pm »
Hi guys
Hopefully someone has an idea as to what is causing this I have been trying to fix it all day but to no avail.
If you have any suggestions please get back to me
Lea
srabelpawz
  • Last login:May 16, 2010, 11:07:44 am
« Reply #3 on: May 25, 2005, 10:18:34 am »
  i had this problem too. i think i regenrated the list again and it worked
vibez
  • Last login:February 09, 2011, 08:33:20 am
« Reply #4 on: May 25, 2005, 11:08:02 am »
Not mentioning that you downloaded the games might get you more help.
Have you thought that the games may not be compatible with what ever version of mame you are using?
M.A.M.E Power
« Reply #5 on: May 25, 2005, 03:40:25 pm »
Hi
I am using the latest version of mame 0.96 do you think that this is the problem? I am sorry about the roms have now removed that comment.
Sorry
vibez
« Reply #6 on: May 26, 2005, 04:33:53 am »
Go grab clrmame & verify all your roms against mame 0.96. If all the roms pass clrmame's tests. Then post back here & we will see what we can do
M.A.M.E Power
« Reply #7 on: May 26, 2005, 09:00:31 am »
Have started another thread about that, I downloaded and ran ClrMame against all my roms and pretty much ALL of the folders are missing files. However apart from the odd one or two and of course the ones that do not run anyway, not all of folders can be missing files surely!
Please help as I do not no why ClrMame is suggesting that my folders are missing files and subsequently may not work!
Please help.
