Author Topic: SKJukebox error when running for first time - fixed  (Read 4150 times)
whatisk
  • Last login:March 27, 2017, 06:41:39 am
  • Nothing to see here
« on: May 20, 2005, 02:32:56 am »
I am getting the following error when trying to run SKJukebox after installing it:
System Error &H8007007E (-2147024770). The specified module could not be found.
I am running WinXP SP1 and have downloaded the VB6 runtimes and installed (even though I appeared to already have a VB6 DLL installed).
I have installed and run it fine on another PC of mine, however, the one that it giving the error is my MAME cab PC
« Last Edit: May 20, 2005, 07:41:46 pm by whatisk »
No trees were harmed in the creation of this post. Though several electrons were severely inconvenienced.
whatisk
Re: SKJukebox error when running for first time - fixed
« Reply #1 on: May 20, 2005, 07:45:54 pm »
After plenty of experimenting I managed to find what the cause was.
It seems that at some point I installed the jukebox using a non-default filepath and then uninstalled it.
This time when I installed it, I used the default path. All of the registry entries for 'imag*.dll' where still pointing to the original install location. These entries must not be deleted on uninstall or altered on a reinstall to another location.
When I changed all entries in the registry that were pointing to the old location to where it was now installed, it worked!!  :D
SalmonKing
  • Last login:August 16, 2007, 10:45:44 am
  • SK Jukebox
« Reply #2 on: May 20, 2005, 11:31:44 pm »
Thanks for that, I will have a look at my options for unregistering those DLLs when uninstalling.  I'm assuming it was working when installed into the 'non-default' path?
SK.
whatisk
« Reply #3 on: May 21, 2005, 09:09:43 pm »
