Author Topic: nfl blitz 99  (Read 1912 times)
kenzo42
  • Last login:November 23, 2024, 01:11:32 pm
nfl blitz 99
« on: May 16, 2005, 06:12:39 am »
i just picked up an nfl blitz 99 board, without a hardrive. can any hardrive be used when placing the chd files?
is there a website that has more info on doing this?
thanks.
Lilwolf
  • Last login:May 08, 2026, 06:33:59 pm
Re: nfl blitz 99
« Reply #1 on: May 16, 2005, 07:54:24 am »
There is a command in the chdman (whatever) application for checking / creating the chd files.  You take a harddrive and it will put it on the drive.
Search / Ask over at the main mame forums.  Also might want to search at mameworld.net's forums.
But you can... and I believe its pretty easy.  Not sure if you need specific drives or any IDE that the image can fit will work.
tommy
Re: nfl blitz 99
« Reply #2 on: May 16, 2005, 11:01:03 am »
I have an extra Blitz 99 drive it you need one.
GGKoul
  • Cheesecake Apprentice
Re: nfl blitz 99
« Reply #3 on: May 16, 2005, 11:02:54 am »
I remember Peale or someone was able to use the Mame CHD's to re-create the drive.  Search on this board and you'll find something about rebuilding the drive.
