Author Topic: HUGE Mamewah crashes  (Read 1877 times)
chuckaroo2000
  • Last login:November 19, 2005, 03:55:24 pm
« on: May 13, 2005, 06:28:48 pm »
Hello all,
I have been using Mamewah for MAME and everything is great.
jcrouse
    • CPViewer
Re: HUGE Mamewah crashes
« Reply #1 on: May 13, 2005, 08:56:38 pm »
These are usually a hardware/driver issue.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/ddtools/hh/ddtools/BCCodes_db6acb86-ecd5-449e-9b98-e0360a4f1498.xml.asp
Check the stop codes. Also do a Google search, you'll see it's a common problem.
On a side note, for a home system, ALWAYS go into Control Panel/System/Advanced/Startup and Recovery/Settings and UNCHECK the option "Automatically Restart". This is the FIRST thing I do after a fresh reload. I've seen systems get into an endless loop of BSOD...Reboot....BSOD...Reboot. The only way to stop them was a parallel install but that's an entirely different subject.
Good Luck,
John
chuckaroo2000
« Reply #2 on: May 14, 2005, 12:06:16 am »
Thanks for the response.  After reading the link it sounds like it could be a hardware problem, maybe faulty memory or something.  When adding new emulators to Mamewah I first set it up on another computer then when I got it going I install it on the cabinet.  I haven't had problems on the other computer.  I will have to study the link a bit harder but I sure hope it is a simple fix.......
Thanks again!
chuckaroo2000
« Reply #3 on: May 15, 2005, 07:37:31 pm »
I found the problem.  I use PivotPro to rotate my screen.  IF my screen is rotated, Z26 and FCEUltra will crash the system IF used through Mamewah.  I guess this poses another problem....does this mean I can't use those emulators through Mamewah??  I need my screen flipped 180 to play.  I ordered my monitor backwards.  It's a cocktail cab.
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
« Reply #4 on: May 15, 2005, 08:46:24 pm »
There are other NES hacked emulators out there for use in a cab...screenshotarchive.com has some I believe
