Author Topic: horizontal frequency question  (Read 1658 times)
skydemon
  • Last login:November 08, 2005, 11:38:24 pm
« on: May 13, 2005, 12:34:01 am »
Hey all, just a quick question...
Just wondering if all the people with duel freq monitors (15/25Khz) use the low or high setting? Im testing mine on high but it means I cant select a lot of lower res in advv due to the high vertical freq it usually specifies (100Hz or so) for 25Khz monitors. The only way I can see to choose these resolutions is to change the monitor to the low freq setting...
skydemon
Re: horizontal frequency question
« Reply #1 on: May 16, 2005, 07:07:57 pm »
bump
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
« Reply #2 on: May 17, 2005, 03:52:54 am »
Monitors always display the same number of lines regardless of resolution.
In 25KHz your monitor displays ~350-400 lines and in 15KHz it displays ~240-290 lines.
If you display a lowres resolution (e.g. 320x240) in 25KHz it will only occupy ~2/3 of the screen.
(If you are interested in how to display the lowres resolutions in 25KHz anyway, I'll explain it in another post)
skydemon
« Reply #3 on: May 17, 2005, 11:11:10 pm »
Ah ok that makes sense, could you explain how to display the lowres res at 25Khz though? thanks mate!
radMonkey
  • Last login:May 18, 2005, 06:55:34 am
« Reply #4 on: May 18, 2005, 06:55:34 am »
What are you using? Linux or Windows? What software will you be running? MAME?
skydemon
« Reply #5 on: May 18, 2005, 11:08:00 pm »
its running in dos right now (may be putting in linux eventually)
im running advmame (latest version) and advmenu on a nanao 26" monitor with dual 15/25Khz
